Team Rush coil replacement - JeepForum.com
post #1 of 3 Old 09-27-2020, 06:59 AM Thread Starter
rebelles
rebelles's Avatar
I have looked around at a lot of the Team Rush info and have not yet run across what, if any, MSD Coil is currently available that is a direct canister style replacement for the stock coil. I’m the write-ups from year’s past, the recommended part was the MSD Blaster 2F (part #8205). Does anyone know if there is a newer model that would fit the with the factory wiring connector?
85 CJ7 Spring Special, 2 1/2" SkyJacker, YJ shackles, 32" BFG ATs
03 TJ
80ish CJ7, current project
rebelles is offline
post #2 of 3 Old 09-27-2020, 11:20 AM
oldschool74cj5
hello
when i did mine i used a pertronix 40,000 flamer thrower canister coil. works well for me. it fits the stock coil mount but i did have to cut the stock coil connector off and install terminals on the wire. i actually like better becaue i was never crazy for the ford style slip on connection.
oldschool
oldschool74cj5 is offline
post #3 of 3 Old 09-27-2020, 06:14 PM Thread Starter
rebelles
rebelles's Avatar
Originally Posted by oldschool74cj5 View Post
hello
oldschool
Thanks. I have seen MSD Canister coils that have that type connection. I was just hoping to find a direct replacement and avoid cutting wires.
03 TJ
rebelles is offline
