T 18 Transmission in 79 cj5 - JeepForum.com
 2Likes
  • 1 Post By JERSEYJOE
post #1 of 10 Old 10-17-2021, 08:03 PM Thread Starter
rkmellott65
1979 CJ5
I'm just wondering I thought I was told one time at in 79 jeep only put the t 18 transmissions in 150 cj5's I'm probably wrong can some one help me out with this I got a 79 with a 258 and a t 18 Trans. Thank you
rkmellott65 is offline
post #2 of 10 Old 10-17-2021, 10:06 PM
Kilrain
1979 CJ5
The 1979 CJs most definitely came with the T18A, there is the window sticker from mine:
This is additional info from Novak that I can confirm via the shift pattern on my 1979:
All Jeep CJ's from 1977 to 1979 had wide-ratio T18 with the 6.32:1 first gear. No front adapter plate is present on these models. 1976-1979 T18 transmissions can be adapted to GM V6 or V8 by use of a T18 adapter kit that we manufacture, kit #1879. Jeep CJ T18's from 1976-1978 may be cast with #13-01-097-907.
The 1979 Jeep CJ T18 is similar to the 1976-1978 versions, except that it features a wider front bearing and a different top cover with aluminum shift forks and a different shift pattern with reverse gear being over to the right and down. These T18's may have a case casting number of 13-01-065-904 and a top cover casting of #13-01-065-906.
1979 Jeep CJ-5 Golden Eagle, Morocco Buff, 258 L6, Howell FI, JeepAir A/C, T18, Dana 20 TC
Kilrain is offline
post #3 of 10 Old 10-18-2021, 07:07 AM
JERSEYJOE
JERSEYJOE's Avatar
T-18 in a cj 7
I beg to differ. the T-18 that came in all the CJ series had like a 4.21 FIRST GEAR. The T-18's that came in full size Jeep trucks had the 6.32:1 granny low first gear. Parts Mike makes a conversion kit to convert the Full size truck transmission for use in the CJ since the input shaft on the full size truck is twice as long as the CJ input shaft. I have done several on these conversions.
uptillnow likes this.
SPEED COSTS MONEY: HOW FAST DO YOU WANT TO GO?
JERSEYJOE is offline
post #4 of 10 Old 10-18-2021, 07:24 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Actually, I believe it was a 4.09 first gear. 2nd and 3rd gears were also numerically lower than T-18s with the granny low.
Matt
Matt1981CJ7 is offline
post #5 of 10 Old 10-18-2021, 07:41 AM
JERSEYJOE
JERSEYJOE's Avatar
T-18
Matt I am sure that you are correct as I did not know the exact CJ ratios except that they were different. Thanks for the update.
post #6 of 10 Old 10-18-2021, 09:20 AM
JeepinGeo
JeepinGeo's Avatar
Many of these guys know more about this subject than I do and are actually the ones who helped me, but given that I just tore apart my T18 3 days ago for a $1 repair, I'll offer what I know. Jeeps from the factory in the years mentioned above, if paired with the T18, first gear was a 4:1 give or take first gear ratio. It was the Ford T18A that had the 6.32:1 first gear (the one I bought and adapted). Therefore, if it's factory Jeep T18, its likely to be the 4:1 ratio.
JeepinGeo is offline
post #7 of 10 Old 10-18-2021, 10:55 AM
Kilrain
1979 CJ5
Here is the link to the Novak Conversions page about the T18. Pretty sure they are a trustworthy source regarding transmissions and such, which is why I cited them in my initial reply. Do with the information what you will:
https://www.novak-adapt.com/knowledg...manual/t18-t19
Kilrain is offline
post #8 of 10 Old 10-18-2021, 10:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
That reminds me when people say they never put a T-177 in a CJ only T-176 although a lot of people find then in their CJ's anyway.
I'm sure they put in whatever was available. Just like Dana 44's in '86 Jeeps.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #9 of 10 Old 10-18-2021, 11:12 AM
JERSEYJOE
JERSEYJOE's Avatar
T-18
The finished product: Jeep J-20 T-18 with Scout Dana 300 transfer case, a direct bolt on no adapter
John Strenk likes this.
post #10 of 10 Old 10-18-2021, 11:18 AM
John Strenk
1976 CJ5
Best of all worlds.... !!
