T 176 Transmission ? - JeepForum.com
 4Likes
post #1 of 21 Old 10-24-2021, 11:36 AM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
Anyone have an idea why this would happen?
Kickstart is offline
post #2 of 21 Old 10-24-2021, 11:37 AM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
The picture did not load, will try again.
post #3 of 21 Old 10-24-2021, 12:01 PM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
Cannot get the picture to upload, will try again later.
post #4 of 21 Old 10-25-2021, 05:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I'm curious though. Can you describe what happened?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #5 of 21 Old 10-25-2021, 07:07 AM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
John, are you asking about the trans or posting the picture?
post #6 of 21 Old 10-25-2021, 07:08 AM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
Now I see the post count is not high enough. Sorry
post #7 of 21 Old 10-25-2021, 11:11 AM
John Strenk
1976 CJ5
Just the problem with the trans.
post #8 of 21 Old 10-25-2021, 11:23 AM
80cj
80cj's Avatar
1980 CJ5
Here's your pic
RiverandSand likes this.
80cj is offline
post #9 of 21 Old 10-25-2021, 12:08 PM
RiverandSand
1980 CJ5
How do the pins look? Could be incorrect install, age or just worn out. Replace the cap, spring and usually a dust cover comes with it. Check the pins for wear too.
RiverandSand is offline
post #10 of 21 Old 10-25-2021, 02:31 PM
John Strenk
1976 CJ5
Iím thinking cheap crown replacement cap and pushing the shifter too far?
Iíll have to look at mine again to be sure but the crown replacement one is much thinner than the oem one.
post #11 of 21 Old 10-25-2021, 03:59 PM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
I see no wear on the pins.
post #12 of 21 Old 10-25-2021, 04:04 PM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
John, Yep a crown replacement and I thought it was too thin (cheap). It didn't last very long.
Do you know where I could get a OEM or a better than Crown Shifter control housing cap?
Thanks
post #13 of 21 Old 10-25-2021, 04:06 PM Thread Starter
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
Thanks
80 CJ
post #14 of 21 Old 10-25-2021, 08:25 PM
John Strenk
1976 CJ5
Thanks
Might try ebay for OEM stuff. Not sure if anyone else has any
Kickstart likes this.
post #15 of 21 Old 10-25-2021, 08:42 PM
Girth83
1982 CJ5
I'll have to open mine up eventually, so this is good to know. A search for T176 parts and "housing cap" found that Novak sells parts, though I'm not sure whose parts they sell. https://www.novak-adapt.com/catalog/...rts/t176-parts Most other suppliers seem to sling the Crown part, but might be worth a call to Novak. Also found a Mopar part on ebay, sold by deadjeepparts.
Girth83 is offline
