T-176 pops out of 4 gear - JeepForum.com
 1Likes
  • 1 Post By John Strenk
post #1 of 8 Old 04-17-2019, 04:17 PM Thread Starter
UphillBattle
My transmission pops out of 4th when coasting. I have also had issues with not being able to shift into 3rd or 4th without stopping and shifting into reverse (I can shift between 1st and 2nd, just not into 3rd or 4th and the transmission is in neutral, not stuck in a gear when this occurs). Not sure if these are related problems. The transmission pops out every time when coasting in 4th. The second issue has only occurred a few times in cool weather and when accelerating quickly. I had a manual transmission mechanic look over the transmission prior to the rebuild and said all was well. I have been told that when a transmission pops out of gear it is the synchronizer but I would not expect a 4 gear synconizer to go bad. I am thinking it may be a worn synchronizer plate or weak synchronizer spring but thought I would experience the same thing in 3rd gear if this were the case (which it is not).
This 1980 CJ5 was an old plow jeep and I did have to replace the transmission case cover due to it being broken at the fulcrum pin.
Any guidance would appreciated. Sorry for the long winded post.
UphillBattle is offline
post #2 of 8 Old 04-17-2019, 04:22 PM
LumpyGrits
Cj
First sign of a worn T-176.....
Rebuild time.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 8 Old 04-18-2019, 06:09 AM
John Strenk
John Strenk's Avatar
1976 CJ5
How long ago did he rebuild it?
Do you have to stop the jeep to shift from 3 to 4 or just stop moving the lever and let it sit in neutral for a few seconds between 3 and 4 ?
It almost sounds as if the 3-4 fork that slips around the synchronizer ring is in the wrong location. This might throw off how the interlocks works and may not let the ring sit fully in 4th gear.
It would be interesting to see how the gates line up in each gear. Or putting it into 4th, remove the shift lever and see if you can push the gate further. forward.
Of course a worn out input bearing will allow too much slop that might force the ring out also.
Also make sure two of the cover bolts have the long shoulder that aligns the cover properly are installed. If he used the same bolts in all the positions you could not be sure the top is in the correct location. This could prevent you from fully engaging 4th .
Rollbar likes this.
John Strenk is offline
post #4 of 8 Old 04-18-2019, 09:37 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Popping out of 4th is usually a sign of the syncro ring not engaging completely or excessive movement in the output shaft.
Worn/loose shift fork (driving around with your hand hanging on the shifter)
Bad output bearing (vertical/lateral movement in the mainshaft)
Loose bull gear (some models)
Excessive clearance between the gear and the mainshaft (rare)
The second problem almost sounds like a interlock pill issue. or the rails not being properly aligned. I would be curious to see if the rail gates were parallel when this happens.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #5 of 8 Old 04-20-2019, 05:41 PM
Marshall78
Jeepdaddy is correct. Popping out of gear when not under power is a sure sigh of a worn synchro ring. Rebuild time.
Marshall78 is offline
post #6 of 8 Old 04-20-2019, 07:15 PM
LumpyGrits
Cj
The brass synco ring does not hold the tranny in gear.
LG
post #7 of 8 Old 04-21-2019, 02:50 AM
80cj
80cj's Avatar
1980 CJ5
LG
They probably meant synchro sleeve. But I agree with you that it's probably rebuild time. Worn bearings allow the mainshaft to move back and forth causing synchros to slip out of gear.
80cj is offline
post #8 of 8 Old 04-21-2019, 09:13 AM
jeepdaddy2000
1971 CJ5
LG
Your correct. I mislabeled my part.
Thomas Payne
4th gear , t-176
Regearing from 4.88 to Revolution Gear's new 5.38. Jerry Bransford TJ Wrangler Technical Forum 45 04-26-2019 10:09 AM
D30 CAD / Axle / Gear knowledge needed 1project2many YJ Wrangler Technical Forum 12 04-08-2019 05:24 AM
Dana 60 What is my gear ratio based on Ring gear stampings?? MMarchi Jeep CJ Forum 2 01-24-2019 06:01 PM
Help!!! Leslielou77 Grand Cherokee General Discussion 8 04-29-2018 07:26 PM
06 WK JGC Laredo fresh/recirculate gear & actuator indexing/calibrating? 68Scout Audio, CB & Ham Radios, GPS, & Electrical 0 12-05-2017 10:22 PM
