switch/sensor identification- side of engine - JeepForum.com
 1Likes
  • 1 Post By John Strenk
post #1 of 12 Old 09-05-2019, 10:54 AM Thread Starter
mc190
Cleaning up the engine on a 258 I6.
Anyone know what this sensor/switch is located on the engine block. It is the one on the left. The other one is the CTO/ Ported Vacuum Switch.
when removing the headers and exhaust, the wiring from that switch separated. Just have no idea what it is.
Thinking about removing the ported vacuum switch as well. Nothing is hooked up to in anyway.
mc190 is offline
post #2 of 12 Old 09-05-2019, 12:10 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Looks like someone put a temperature sending unit in there.
that looks like a bourdon tube attached to it.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #3 of 12 Old 09-09-2019, 07:31 AM Thread Starter
mc190
a better picture of the unknown switch.
mc190 is offline
post #4 of 12 Old 09-09-2019, 07:38 AM
Hoover7
Hoover7's Avatar
I agree with John, looks like an old temperature sending unit. That's where I have mine mounted on the 258.
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is online now
post #5 of 12 Old 09-09-2019, 08:08 AM Thread Starter
mc190
Been too darn hot to work on the Jeep in the afternoons, so have not been able to trace back that wire/tubing to see where it goes.
Assuming its a temp sending unit, were can I get a replacement bourdon tube that John mentions.
mc190 is offline
post #6 of 12 Old 09-09-2019, 11:16 AM
John Strenk
1976 CJ5
You can't. They are a sealed unit from the sensor to the gauge.
You have to replace the whole gauge.
The Bourdon Tube
A Bourdon Tube is a thin metal — usually brass or copper — tube that is filled with an easily vaporized fluid, typically alcohol. It is sealed at both ends. At the gauge end it is formed into a circle or spiral with its end attached to the indicating needle by some form of linkage. The other end is fitted to a water-tight connector that is in direct contact with the coolant in the engine.
As the coolant warms up the alcohol in the Bourdon tube expands. The expansion transfers its force to the coiled end of the tube inside the gauge. As the coil or spiral unwinds it pulls the linkage on the needle, which in turn shows a temperature reading on the gauge face. The gauges are calibrated during the manufacturing stage and are not adjustable afterward.
Since the Bourdon Tube design is purely mechanical the gauge will continue to read some temperature level even after the engine is shut off. As the engine cools the gauge's needle will return to its rest position.
Bourdon Tube gauges aren't used anymore because of cost and convenience factors. The tubes are delicate and must be carefully routed from the dash to the appropriate fitting on the engine. The gauges themselves are far more expensive than electric or electronic gauges and if the tube is kinked or split the entire gauge assembly must be replaced.
Cutlass327 likes this.
post #7 of 12 Old 09-09-2019, 04:51 PM Thread Starter
mc190
Thanks for the explanation on The Bourdon Tube.
Looks like converting it over to an electric style.
mc190 is offline
post #8 of 12 Old 09-10-2019, 09:16 AM
WindKnot
WindKnot's Avatar
1977 CJ7
Hoov
I did that too.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #9 of 12 Old 11-12-2019, 07:43 PM
dkihn
I think that it is the coolant temperature sensor for the temp gauge on the instrument cluster. I've been looking for mine. Thanks
David
dkihn is offline
post #10 of 12 Old 11-13-2019, 05:12 AM
John Strenk
1976 CJ5
David
Welcome to the forum but the temp gauge in the instrument cluster is electronic so it wouldn't have the tube attached.
post #11 of 12 Old 11-14-2019, 08:29 PM
dkihn
Agree, If it is a tube it is the oil pressure sending unit.
dkihn is offline
post #12 of 12 Old 11-15-2019, 07:55 AM
John Strenk
1976 CJ5
Well actually it could be a mechanical water temp gauge if it has a tube.
And the stock oil pressure sensor on the jeep is also electric but that is the easiest to convert to a mechanical oil pressure gauge with the tube you are thinking about.
