swap ever type clutch to diaphragm - JeepForum.com
post #1 of 5 Old 05-11-2010, 05:13 PM Thread Starter
mike06X
i'd like to put a diaphragm clutch into my CJ for the benefits of easier engage/disengage pedal action..i bought a kit but the throwout bearing won't fit my fork (t14 transmission). Can I continue to use my lever type/borg-beck throwout bearing with a diaphragm clutch or are they not compatible?
just trying to avoid getting it installed and finding out my clutch won't release properly because the lever type throwout bearing is too thick or something..
84 CJ7 - AMC360 & T727 | 35 BFG-KM2
mike06X is offline
post #2 of 5 Old 05-11-2010, 05:30 PM
o2tj
o2tj's Avatar
do you mean hydraulic slave cyl set up?
o2tj is offline
post #3 of 5 Old 05-11-2010, 05:33 PM Thread Starter
mike06X
no..i want to change from a lever type, or "borg & beck" coil spring clutch to a "diaphragm" bellville spring clutch..can i use my existing throwout bearing? cause the diaphragm one won't fit my clutch fork..so i can i just use my existing throwout bearing that fits? or do i need a different height one, and accompanying clutch fork.
mike06X is offline
post #4 of 5 Old 05-11-2010, 06:10 PM
o2tj
o2tj's Avatar
Oh, ok tracking now.... Im going to use a cherokee cheif clutch 10 3/4 10 spline on my T5 Its a diaphram type.
o2tj is offline
post #5 of 5 Old 07-30-2010, 09:44 PM
drkennedy61
1981 CJ7
I changed mine from a lever type to diaphram type and the throwout bearing was the same thickness. My clutch workes great
drkennedy61 is offline
master cylinder diaphragm sstumble Jeep CJ Forum 2 08-12-2009 09:51 AM
'95 YJ master cylinder on a '91 single diaphragm booster? Aaroneous Jeep CJ Forum 2 02-16-2009 09:51 PM
YJ Dual Diaphragm Brake Power Booster jfwireless Jeep CJ Forum 16 08-27-2007 09:51 AM
Dual vs Single Diaphragm Brake Booster BUGS Jeep CJ Forum 17 03-10-2006 08:09 AM
What type of clutch? Slipslap Jeep CJ Forum 3 04-22-2005 09:38 AM
