Suspension and Tires - JeepForum.com
 11Likes
  • 3 Post By JoonHoss
  • 1 Post By jurgen24
  • 2 Post By Matt1981CJ7
  • 3 Post By keith460
  • 1 Post By 80cj
  • 1 Post By pg_jglr
post #1 of 11 Old 10-13-2021, 09:47 AM Thread Starter
JeepGuy41
JeepGuy41's Avatar
Cj Suspension and Tires
I have an 84 CJ7 currently with 32 inch tires. The suspension needs to be gone through and replaced but before I do that I would like to have a good ballpark range of what tire size I want to go with. Currently thinking 33 or 34. 34's seem hard to find however for the 15 inch factory rims which I want to keep. Does anybody have photos of their CJ7 on 33s or 34s? Also if you could tell me your lift height it would be much appreciated. It is a daily driver so it can't be too tall in lift height just to keep it from being sketchy. Thanks!
JeepGuy41 is offline
post #2 of 11 Old 10-13-2021, 10:47 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
I've always been partial to 32s and a 2.5" lift on CJ7s.
Here is my '83 with that set up
You won't find a true dual purpose tire in a 34" height for a 15" wheel.
Do you know what your current gears are?
Hoss
Jim1611, Matt1981CJ7 and Axhammer like this.
I used to be a people person, until people ruined it...
JoonHoss is offline
post #3 of 11 Old 10-13-2021, 11:17 AM
jurgen24
33, 2.5 lift, 4.10 gears (with T5) are are good combinations for mild+/medium trail rig.
The only issue I have come across is that some tire shops will not mount a 33 tire on a 7 wide (stock) wheel.
Sent from my iPhone using Tapatalk
JeepGuy41 likes this.
jurgen24 is offline
post #4 of 11 Old 10-13-2021, 11:19 AM
Nick4320
Nick4320's Avatar
Most people here will probably tell you a 2.5 in lift works best. Ik alot of people have an old man emu leaf spring set, with the front converted to the YJ springs.
Me personally I have a rocky road outfitters kit, which is a old man emu conversion. I think everyone who has done this conversion is highly impressed with it.
As for my tires im currently running 33s pro comps. It looks great rides great, but a little rubbing on full flex. So I have a 1in body lift in my future.
Nick4320 is offline
post #5 of 11 Old 10-14-2021, 08:26 AM Thread Starter
JeepGuy41
JeepGuy41's Avatar
Stock gears currently i believe. That is partially why I am trying to figure out what tire setup I want to go with so I can base suspension and gearing off of that and get it ordered especially with shipping delays so it can be done before the new year. I do like the look of that setup.
post #6 of 11 Old 10-14-2021, 10:23 AM
bob4703
1974 CJ5
There is a little known and if known often ignored relationship between tire size and gear ratio. Larger tires also can decrease your braking efficiency. Lifts if not done properly can affect on road driving and make access harder for the ladies of shorter stature.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #7 of 11 Old 10-15-2021, 10:06 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The general rule of thumb is a 2.5" lift will allow 32" tires without any rubbing at full flex/tuck.
33" or taller tires will require more lift.
I'm with JoonHoss, I think a 2.5" lift and 32" tires is the perfect look for a CJ. Anything taller looks weird, IMO, and requires more work to retain good drivability.
Here's mine with 2.5" OME lift and 32"s. As you can see, the 32" tires barely clear the tub at full tuck. 33"s would surely rub.
Matt
JoonHoss and JeepGuy41 like this.
Matt1981CJ7 is offline
post #8 of 11 Old 10-15-2021, 10:41 AM
keith460
keith460's Avatar
Same here, 32" tires and 2.5" lift are an excellent sizes for the CJ for good drivability, road manners and looks. But proper gearing is a must for larger diameter tires in order to take full advantage of a CJ's potential.
I have a 4.10 gears with a T5 and 32" tires, along with a 2.5" OME lift. Great for the hilly terrain I live in PA. You might want to consider 3.73 gears for a much flatter Florida.
I had a 3.5-4" lift, 33" tires and factory 3.31 gears. What a god awful setup that was. Wander on the road as wide tires like to follow the grooves in the road. Gearing that was too low, the Jeep couldn't get out of its own way and a ride that was like sitting in a horse drawn wagon heading out west.
It's no mystery as to why Chrysler has 4.10 gears and 32" tires on factory Rubicon models with the V6 engine. They know what it takes to turn large diameter tires and a vehicle that weighs, when fully equipped, much, much more than a CJ ever did.
80cj, JoonHoss and JeepGuy41 like this.
1984 CJ-7 Renegade
keith460 is offline
post #9 of 11 Old 10-15-2021, 02:18 PM
80cj
80cj's Avatar
1980 CJ5
Nice flexy OME springs...
80cj is offline
post #10 of 11 Old 10-16-2021, 10:40 AM
pg_jglr
1981 CJ5
If you are looking for more of an engineering type look there are several sites that will help. I ran the numbers when planning my transmission / transfer case swap using these sites:
http://www.offroaders.com/info...cor...alculators.htm
http://www.grimmjeeper.com/gears.html
My drive train consists of: AMC 304 --> T-18 (1st @ 6.32) --> D300 (low @ 2.62) --> Stock axials from 81 CJ5 (HH code @ 3.73) --> 33" tires. I originally wanted to go for 32s but i had a hard time finding what i wanted in that size. So far I'm happy with the driveability on pavement, when i do the YJ OME lift and 1" body lift I'm expecting it to be just right offroad too.
Sent from my SAMSUNG-SM-G935A using Tapatalk
pg_jglr is offline
post #11 of 11 Old 10-16-2021, 01:36 PM
80cj
80cj's Avatar
1980 CJ5
In looking at different M/T selections in 32's, I've also noticed that many manufacturers will list 31's and 33's but not 32's.
80cj is offline
