Steering shaft? - JeepForum.com
post #1 of 3 Old 08-01-2021, 09:21 AM Thread Starter
NukeByDay
NukeByDay's Avatar
Steering shaft?
78 CJ7 with what seems to be an aftermarket power steering box. Removed the old steering shaft from the column to the steering box. Order same (or what I thought) shaft with the rubber boot at bottom of shaft but noticed the keyway on the new shaft did not match the old shaft or the box. I noticed I had ordered a steering shaft for a manual steering box. I ordered a shaft for a power steering box and it fits. Question is, the end of the shaft is not booted and instead has a universal joint. Has anyone ran into this before?
NukeByDay is offline
post #2 of 3 Old 08-01-2021, 08:11 PM
Ollie09
1977 CJ5
Should have one of these. Sounds like someone swapped out the original for an aftermarket joint.
Ollie09 is offline
post #3 of 3 Old 08-02-2021, 08:42 AM Thread Starter
NukeByDay
NukeByDay's Avatar
That is what I ordered first but the keyway was wrong. Possible that Summit has the wrong part referenced
