Steering on my MiniJeep - how? - JeepForum.com
post #1 of 54 Old 11-16-2009, 04:28 AM Thread Starter
NaskeOffroad
1953 CJ3B
Hi
I'm bilding a Mini jeep for my daughters. It will be with a stiff rear axel, and a tilting front axel. One 110cc 4-stroke China engine with semi-automatic.
I just don't know how to fix the steering proparly. Ideas? I do have this materail today (see pictures).
Thankful for good (and simple) ideas..
/Benny
[/IMG]
NaskeOffroad is offline
post #2 of 54 Old 11-16-2009, 05:18 AM
Mike Romain
Hard to see your photos from here.... Ooo see them now, sweet!
I have build go-karts and used a chunk of U channel on it's side for the 'ball joint' pivots with a hole on the top and bottom to pass a bolt vertically down through. I then welded a bolt onto the side of this vertical one to make a spindle for a ball or roller bearing wheel and a chunk of 1/4"x1 1/4" bar stock welded off the front of the vertical bolt for the tie rod arm. The steering shaft was just round stock bent at a 90 on the bottom and up about 4" or so to pick up the round stock 'tie rods'.
Mike
Mike Romain is offline
post #3 of 54 Old 11-16-2009, 07:55 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would look at some old garden tractors someone is throwing out. You can find some nice geared assemblies on them. Most of them are vertical but you could find some way of fitting them maybe even rotating it 90* to fit it on an angle. I have a MTD tractor with 4 wheel steering. Thought the rear axle would make a cool front axle for something like that. Power input is a pulley mounted on top.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 54 Old 11-16-2009, 08:13 AM
southshore30
southshore30's Avatar
1982 CJ7
Northern Hydraulics sells small ball joints and linkages for go carts in there magazine. Lots of good stuff for a go cart there, maybe you can use/modify something. That is sweet! good job so far! keep up w the pics
southshore30 is offline
post #5 of 54 Old 11-17-2009, 12:53 AM
Cutlass327
Cutlass327's Avatar
1930 CJ2
I was gonna suggest using a steering system from a lawn tractor.
I like it - keep us posted with your progress!
Rick
1978 CJ5 5.0HO/T177/D300 TerraLow 4:1 kit, '86 D30/D44 3.54 WT axles w/Aussies, 'glass body, 33x12.5 ProComp A/T, TDK galv'd frame, 2.5 OME YJ lift - DD and weekend toy
Cutlass327 is offline
post #6 of 54 Old 01-18-2010, 03:26 PM Thread Starter
NaskeOffroad
1953 CJ3B
Hi there
Now I've come up with a solution. Simple! I'll use two pair of uniballs for the linkage.
So this will solve it! The rest of the steering will be simple!
Soon I'll fixit on th erigg and then I'll add more photos..
/Benny
post #7 of 54 Old 01-18-2010, 03:32 PM Thread Starter
NaskeOffroad
1953 CJ3B
Hi again
Now I have the solution. Unibolts. I'll weld long nuts on the upper and lower side of the front axel(bar). Fit one unibolt in each nut and then fix the wheel axel with and vertical bolt through the axel. The rest of the steering will be simple. Just an easy linkage - done! I'll come back later with more picture when I've fixed the steering.
/Benny
post #8 of 54 Old 01-18-2010, 11:41 PM Thread Starter
NaskeOffroad
1953 CJ3B
Hi friends
I've slve it now. I'll weld two nuts on each side (up and down) and then mount unibolts to fix an bolt trough my wheel axel. An easy and simple solution. The rest of the steering will be simple.
/Benny
post #9 of 54 Old 10-07-2010, 12:39 AM Thread Starter
NaskeOffroad
1953 CJ3B
Hi again
Now it's soon ready for paint. The simple solution for the steering was solved with the head from a grinder!
I also need to change the back sprocket from 30 to 60 teeth - it's TOO fast right now..
I'll post the pictures when it's painted.
See you!
post #10 of 54 Old 10-07-2010, 05:59 AM
Dudman5703
Dudman5703's Avatar
2016 JK Wrangler
That thing is SWEET.
I can't wait to see it finished.
They should LOVE it.
°llllll° Money well wasted
Dudman5703 is offline
post #11 of 54 Old 10-07-2010, 06:18 AM
4lowherewego
1979 CJ7
you can sell that thing after they get older for a couple grand probably....
unique items haven endless resell value...cuz well they r unique
I LOVE IT!!! If later on down the road the girls are too big for it and you want to get rid of it (remeber me I have 9 month old son that will LOVE THAT...hes seen dad rebuilding the CJ5 for 4 months now.
4lowherewego is offline
post #12 of 54 Old 10-07-2010, 06:25 AM
son-of-england
Defiently the first time ive heard of a jeep being too fast!
But that thing is damn sweet, i just hope you realize you just started an even more expensive hobby than shoes for your daughters
son-of-england is offline
post #13 of 54 Old 10-07-2010, 10:13 AM
4lowherewego
1979 CJ7
friend of mine has advice...
move or cut front bumper down(touching tires in pic above)
also.... make a spot for a mini winch =)
post #14 of 54 Old 10-07-2010, 10:32 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
fantastiskt projekt!
Visste du bygga Jeep kroppen själv? proportionerna verkar perfekt!
Jag kan inte vänta att se den finska (eller är det svenska)
det gäller
Hoss
I used to be a people person, until people ruined it...
JoonHoss is offline
post #15 of 54 Old 10-07-2010, 11:50 AM
kickingprop
kickingprop's Avatar
Mycket imponerande!
Med lite mer teknik du kan marknadsföra och sälja dessa över hela USA
Jag kan använda Google Translator också!
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Coupler connecting steering gear to steering shaft is leaking? Natto123 Jeep CJ Forum 1 06-29-2008 12:52 PM
Trouble removing steering gear from steering shaft.... Natto123 Jeep CJ Forum 5 06-29-2008 10:56 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 06:16 PM
