steering column,tilt 80 cj5 ...problem! - JeepForum.com
 2Likes
post #1 of 18 Old 09-07-2019, 01:21 PM Thread Starter
cj5orion
1980 CJ5
WELL...I was changin out my ignition switch,taking my time doing it.
Had (!!!!),,,, all the parts layed out for reassembly
buddy of mine returned a tool and put it right on top of everything and mixed em all up !
I might as well thrown em in a bucket !
Anyway,,,what I'm looking for is a GOOD schematic to put everything back !
All I can find is non-tilt,non-key,manual steerin,automatics,or "way" diff year applications !
1980 cj5,tilt,power
cj5orion is offline
post #2 of 18 Old 09-07-2019, 01:59 PM
258
Maybe these will help. How far are you in terms of part placement?
258 is offline
post #3 of 18 Old 09-07-2019, 02:14 PM
Ollie09
1977 CJ5
It's a GM column so go here and look for what you need.
http://jimshea.corvettefaq.com/?cat=5
258 likes this.
Ollie09 is offline
post #4 of 18 Old 09-07-2019, 08:56 PM
Hoover7
Hoover7's Avatar
Here are a couple other resources I've gathered while overhauling my tilt columns. They might also be helpful-
Tilt Column Fix.pdf
Jazzman's write up here was also an excellent guide for the tilt GM column.
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #5 of 18 Old 09-07-2019, 11:22 PM
Hurricane4
1979 CJ5
Another Resource:
http://www.steeringcolumnservices.com/
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #6 of 18 Old 09-08-2019, 10:30 AM Thread Starter
cj5orion
1980 CJ5
update...sort of...????
gettin some stuff back on...but
when I bolt on the ign switch assbly,,,so that the ign rod works , the steering mount bracket doesnt line up.
tried switchin directions on both...not workin.the mounting bracket should go one with the aluminum inserts slots facing the cab...correct?
On the switch assbly...theres that "3rd mounting hole" ...towards the cab or towards the eng.?
cj5orion is offline
post #7 of 18 Old 09-08-2019, 10:35 AM
Hoover7
Hoover7's Avatar
Some pictures would be helpful here. Post up a few-
Hoov
Hoover7 is offline
post #8 of 18 Old 09-08-2019, 10:46 AM Thread Starter
cj5orion
1980 CJ5
oh yeah...one more q.
when I first started assembly,the ign rod was pointing straight out from the column,I assuming it got bent...somehow.Easy,(sort of), to bend in either direction with a channel lock pliers
so,does it slide into the assbly from the "floor side" or the top ?
does it go "thru" the mounting bracket or off to the side
cj5orion is offline
post #9 of 18 Old 09-08-2019, 11:06 AM Thread Starter
cj5orion
1980 CJ5
OK...2 pics here showing ign rod to assbly ...problemo
ign rod is on the floor side of the assbly
1 st pic key is on,rod slightly askew of assbly.
2nd pic key off,rod badly askew of assbly !
the assbly is on the column the only way I can get the mounting bracket back on.
between these pics n the 2 previous...MAYBE...one of you guys can tell whats wrong !!!!
I'm jus flip flopin things around trying to make some sense out of all this.
gettin real close to a "trail repair" ,"jus make it operable", repair !
cj5orion is offline
post #10 of 18 Old 09-08-2019, 11:26 AM
Hoover7
Hoover7's Avatar
The orientation of the rod looks correct. Just wondering, there are two types of ignition switches - one for tilt columns, one for non-tilt. Is the new replacement switch specifically for a tilt application?
Hoov
Hoover7 is offline
post #11 of 18 Old 09-08-2019, 11:30 AM
Hoover7
Hoover7's Avatar
Check out this thread-
https://www.jeepforum.com/forum/f8/r...witch-4315635/
Hoov
Hoover7 is offline
post #12 of 18 Old 09-09-2019, 02:52 AM
80cj
80cj's Avatar
1980 CJ5
My CJ-5 has the tilt column and if the column is tilted, I can't get the engine to crank. What causes this? Been like that for a while. Hate like heck to get into the column. I bought a new switch but haven't tried installing it yet.
80cj is offline
post #13 of 18 Old 09-09-2019, 06:24 AM
Hoover7
Hoover7's Avatar
Bob, I assume you mean the engine will not crank when the column is tilted in the up position? If so I had the same problem- when mine was tilted up, turning the key cylinder would not engage the 'crank' position on the switch- ultimately, I had to press down on the column (tilted fully down) to start the engine and finally, it wouldn't crank at all. In my case, the switch itself was fine. When I dug in deeper, it turned out to be a worn rack and sector (yep, required a column disassembly). I replaced mine with this Dorman ignition switch kit from Amazon. I found that the plastic gear was worn, and wouldn't move the connecting rod quite far enough to work.
Although it seems daunting, getting into the column wasn't that bad. I'll add this, though- like anything, having the correct tools makes the process go much easier. The pivot pin puller and lock plate compression tool were worth the money IMHO. Although you don't have to pull the pivot pins to replace the rack and sector, I figured while I was in that far, may as well inspect and lubricate the ball joint while I was at it.
Hoov
258 likes this.
Hoover7 is offline
post #14 of 18 Old 09-09-2019, 10:23 AM
80cj
80cj's Avatar
1980 CJ5
Thanks Hoov. Thats what I figured. It cranks in the straight position but undoubtedly, the same problem as you describe. I already have the the lock plate tool. Should get the pivot pin tool.
80cj is offline
post #15 of 18 Old 09-09-2019, 10:38 AM
258
That's good advice Hoover7.
You definitely need the puller tool but the one I used looks like the one in the link provided below. Double check to make sure you get the one that works best for your column. Not sure if they make a difference but double check.
https://www.ebay.com/itm/Steering-Pi...AAAOSwQmJcZ~Oc
ADDITIONALLY, when you finally get to that point in the column after using the pivot tool, remove the knuckle joint via the 3 or 4 bolts (can't recall) and apply "Red Locktite" on the threads and retighten. You won't regret it and it will stop the bolts from vibrating loose in the future; i.e., TIGHT TILT STEERING!
Check out the link. It's a good price!
258 is offline
