Steering Column Bearing - JeepForum.com
 1Likes
  • 1 Post By sonnychiss
post #1 of 7 Old 07-15-2021, 03:32 PM Thread Starter
JeepinGeo
JeepinGeo's Avatar
In the midst of removing old wiring from the engine bay, I noticed the lower steering column bearing has extreme play in it. I can move the lower steering shaft up/down and side/side ~1/4". This is on a 77 CJ5 without tilt column. The steering shaft itself is a newer HD unit. I installed it and the steering column bearing kit a year ago. It has power steering. I can't figure out why this bearing would go bad so quick. It explains the occasional clunking noise I get from the column, but I don't want to replace it without solving the underlying problem. Its not urgent but any advice is, as always, greatly appreciated.
JeepinGeo is offline
post #2 of 7 Old 07-15-2021, 04:41 PM
222Doc
222Doc's Avatar
i am guessing it is sealed so there is no service. year is not that much miles for most Cjs to wear out that i would think. long as it installed ok. sounds like a new one again. nothing odd like the steering shafts u joints ok all connections/rag what ever it has? i would guess if you know the size there might be a heaver duty one that fits and where to to find it?, may not be as well. but there should be no need for a super duty bearing here really. stock should do for decades?
even a timken should be enough lol.
222Doc is offline
post #3 of 7 Old 07-15-2021, 05:20 PM
jlkeener
1980 CJ5
There is a member of this forum who makes a better steering bearing. I can't remember his name but I have one in the shop. Hopefully another member will jump in and identify who it is. I will be in the shop tomorrow and get the info if nobody chimes in.
jlkeener is offline
post #4 of 7 Old 07-15-2021, 06:08 PM
sonnychiss
1978 CJ5
Wolff Engineering makes a very good replacement that is a huge upgrade over the stock design. There is a link and discussion in this thread.
https://www.jeepforum.com/forum/f8/w...aring-4421285/
Sparkybob likes this.
sonnychiss is offline
post #5 of 7 Old 07-16-2021, 08:46 AM Thread Starter
JeepinGeo
JeepinGeo's Avatar
Thanks for the questions and suggestions. I have no problem upgrading or changing to a different setup. The current kit and bearing I installed is a direct replacement Crown. I am aware Crown is in no way super high quality, but for a small $22 bearing and nylon bushing I would have thought it'd do better. I'll look into Wolff. The HD steering shaft u-joints still look good and act brand new. The column itself is secured and properly tightened with no movement or play. The only play is in the internal upper steering shaft itself, right at the bearing where it couples to the lower steering shaft. Like I said I will look into the Wolff upgrade. Thanks all.
post #6 of 7 Old 08-02-2021, 03:40 PM Thread Starter
JeepinGeo
JeepinGeo's Avatar
Well I bought the Wolff Engineering bearing kit. Installed it with ease. It appears to be holding up quite well and will have hopefully solved my sloppy steering issue. Thanks for the suggestion yall.
post #7 of 7 Old 08-23-2021, 02:50 PM
Colt44
Colt44's Avatar
1983 CJ7
A little after the fact, but:
https://www.jeepforum.com/forum/f8/w...eview-4313445/
"Let all the laws be clear, uniform and precise:
To interpret laws is almost always to corrupt them."
~ Voltaire
Colt44 is offline
