steering advice CJ7 with a spring over lift - Page 2 - JeepForum.com
post #16 of 25 Old 09-03-2019, 08:06 PM
MetalMountainGoat
MetalMountainGoat's Avatar
To make this thing drive right, you will need the high steer kit or an axle swap all together to something like a scout 44.
Just like what was said above, you will need the anti wrap bar in the back in order to keep the AMC 20's pumpkin at the correct angle.
I realize that spring over gives you all the lift you want and better articulation, but unless your willing to put the coin in to do it right, it isn't worth trying to do it. A cobbled together SOA is worse than any other type of lift you can buy.
MetalMountainGoat is offline
post #17 of 25 Old 09-09-2019, 09:45 PM Thread Starter
xtholmes
I’ve been eyeballing these links. It answered my question before I asked about brake calipers.
Is my axle shaft still gonna work if I keep all the original Dana 30 parts or am I gonna have to change that up too?
No they did not put an anti-wrap in the back. I can tell my pumpkin is definitely at an angle.
xtholmes is offline
post #18 of 25 Old 09-10-2019, 12:40 AM
MetalMountainGoat
The angle will only get worse over time.
post #19 of 25 Old 09-10-2019, 12:45 AM
ddawg16
ddawg16's Avatar
I'm running SOA with 0 issues.
The key is getting the caster angle set properly before welding the perches. I don't even have my stabilizer shock on and 70+ on the fwy...with 35" tires? 0 Issues.
ddawg16 is offline
post #20 of 25 Old 09-10-2019, 12:50 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
By axle shaft i take it you mean the shaft between the diff and the knuckle? yes, it will last for a while. If you use this only on highway in 2WD, it will last a long time. 35" and D30 off road is not a great combo, and it i more than just upgrading the axle shafts to chromolly, you would also need stronger joints, lockouts and strengthening to the entire case and ends of the axle. If i had to put money on it, the first parts to break will be the joints or the lockouts.
The Dana 30 / AMC20 combo soldiers on in Cjs because they came that way, not because they are the strongest combo. With 35" tyres you should be thinking about single piece axle shafts in the rear AMC20 as one of your first of many expenses. the two part shaft fails even in mild situations as torque reduces on the axle Nut and the parts fret and fail.
Have a look at your rear driveshaft. Is it a simple shaft or a double cardan CV joint? When you lift them you should look at teh angles and if in any doubt change to a double cardan. this will require twisting the pumpkin so it points at the transfer case output, instead of being parallel. Being at angle is either good or bad, depends on the driveshaft. Fortunately they are relatively cheap but you have to get teh alignment right, which is usually a matter of rewelding the spring perches or shimming. the anti wrap bar is to stop the springs from getting all bent up with the extra moment and you bunny hopping down the road, it is not about static alignment. You may or may not need it.
By this time you are probably realisng that going back to stock is cheaper than fixing it up. Big SOA lifts are not for the faint hearted, there is a lot of science and money in it. As soon as you go above about 3" of list, you need to think through every component or you may end up with a wayward slug which drives horribly and is awful slow.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #21 of 25 Old 09-10-2019, 12:52 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
if you fill out your profile you may get more accurate, but still wrong, answers
post #22 of 25 Old 09-10-2019, 07:08 AM
skizriz
skizriz's Avatar
1978 CJ7
I’m gonna look into those for sure!!
Stay away from them. I was warned, didnt listen, bought one and took it back off the next day. Scrapped it because i didnt want to sell it to somebody else.
Buddy of mine just spent 12 hours recovering his jeep after his failed on his TJ.
skizriz is online now
post #23 of 25 Old 09-10-2019, 08:05 AM Thread Starter
xtholmes
I tell ya, it is definitely an interesting journey going with an SOA lift. I can totally see how it is way cheaper to turn around now and take the SOA off🤦‍♂️ I got some CJ soul searching to do! Lol
xtholmes is offline
post #24 of 25 Old 10-19-2019, 10:37 AM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
Originally Posted by mopar440cu View Post
I have a couple Jeep CJ's with Rocky Road OTT kits and love them so far.
Mopar - Sent you a PM....
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #25 of 25 Old 10-20-2019, 09:36 AM Thread Starter
xtholmes
I just discovered them as well! Such an awesome, and relatively cheap, solution for a high steer solution for the Dana 30!! I kept the SOA because of the Rocky Road OTT!!
xtholmes is offline
