steering advice CJ7 with a spring over lift - JeepForum.com
post #1 of 25 Old 08-31-2019, 09:24 AM Thread Starter
xtholmes
Im new to the jeep world and I just snagged a clean 1980 CJ7. It has a spring over lift on it currently. It drives pretty nice considering it has 35"s on it. It does not have a steering stabilizer on it and it has the original steering set up from 1980 with no modifications other than the spring over lift.
I have every intention of making this my daily driver. With that in mind, what are the first two steering upgrades that I should consider so that my steering is absolutely flawless that would allow me to get up to interstate driving speeds without feeling like im about to go on a kamakazee mission I may never return from? lol
xtholmes is offline
post #2 of 25 Old 08-31-2019, 09:36 AM
jurgen24
Add a picture showing how parallel to the ground the drag link is and take a rough measurement of the caster. I assume it’s a D30 axle?
Sent from my iPhone using Tapatalk
jurgen24 is offline
post #3 of 25 Old 08-31-2019, 01:10 PM Thread Starter
xtholmes
Here are those pics. I took a few to cover different angles. It has a z-Link? Also, I’ve heard of flipping the ends, but if I do they will hit the springs.
E6232B04-5B7B-4127-B1D7-1014808C941A_1567274835303.jpg   15FED912-8D76-4023-BB4E-45A8FDDB6887_1567274884345.jpg   E1F09C66-63CC-408D-9A63-4B7C5CF5CA62_1567274922038.jpg   BEDD8C97-D5A1-4AAF-9DAE-69799EAD3BDB_1567274962838.jpg
xtholmes is offline
post #4 of 25 Old 08-31-2019, 01:11 PM Thread Starter
xtholmes
Yes it is a D30 amc 20? At least, this is what I was told
xtholmes is offline
post #5 of 25 Old 08-31-2019, 07:12 PM
stripperguy
Even though you have a z link drag link
It’s the joint locations that matter
As such you have a large angle between the effective drag link and your tie rod
You probably have a lot of bump steer
Look into a hi steer modification
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is offline
post #6 of 25 Old 08-31-2019, 07:29 PM
Rtracy2001
Definitely look into a high steer setup. The most popular ones install Dana 44 knuckles onto the Dana 30, though it may be better to just upgrade to a Dana 44. That is what I did.
Every 20 minute job is just one broken bolt away from a three day ordeal.
Rtracy2001 is offline
post #7 of 25 Old 08-31-2019, 08:05 PM
jurgen24
What kind of wheeling you want to do? If you ever put a locker in the front with 35” tires, your D30 will be toast.
I would recommend two approaches (either should have 6 to 7 degree of caster) and give you a decent highway ride.
1) $$, change to spring under, 3” to 4” lift and 33” tires, drag link flip and optionally tie rod flip.
2) $$$$, swap out the D30 to a D44 with Chevy flat top knuckles and high steer, YJ springs, 35” tires.
I am not familiar with AMC20, but suggest rear axle is as strong as front (so for option 2) D44 of Ford 9”)
jurgen24 is offline
post #8 of 25 Old 09-01-2019, 10:31 AM Thread Starter
xtholmes
Awesome!! I appreciate you all. I got some thinking, research and work to do!
xtholmes is offline
post #9 of 25 Old 09-02-2019, 08:02 AM
mopar440cu
mopar440cu's Avatar
1979 CJ5
I have a couple Jeep CJ's with Rocky Road OTT kits and love them so far.
1979- CJ5- SOA, 304, T18,D20, D30,Model 20 with trac loc/moser axles both 4:56 geared and 35 TSL swampers.
1978- CJ5-SOA,9:1 360/340HP, T18A,D20, D30 and M20 w/4:56 geared.
1979- CJ5 SOA 360, T-18/D20, 4:88 gears,36 Swampers.
mopar440cu is offline
post #10 of 25 Old 09-02-2019, 01:09 PM Thread Starter
xtholmes
I’m gonna look into those for sure!!
xtholmes is offline
post #11 of 25 Old 09-02-2019, 04:15 PM
MetalMountainGoat
MetalMountainGoat's Avatar
Mine had that exact same setup on it when I got it. It was dangerous at any speed over twenty mph. Honestly, if you are looking to fix all of this and stay on the cheaper side, I would recommend going back to a spring under setup and going down in tire size. SOA can be done correctly, but it takes a lot more than just flipping the axles to the underside of the leafs. There is a lot of geometry that goes into the steering angles, and castor angle that needs to be correct in order for it to drive properly
MetalMountainGoat is offline
post #12 of 25 Old 09-03-2019, 01:40 PM Thread Starter
xtholmes
This is what I am discovering. I paid a shop waaaaaayyyy too much to have this SOA put on so I figured they new what they were doing down in Dallas. Thing drives way worse than when I originally took it to them🤦‍♂️
I think I’m gonna try and have steering correct the right way. It’s got an appointment to 4wheel parts shop for an alignment assessment.
xtholmes is offline
post #13 of 25 Old 09-03-2019, 04:23 PM
Fourtrail
1974 CJ6
First link is the new knuckles for high steer. This kit comes with a single hole pass side knuckle, you can either convert to the 'T' style steering or call and have the pass side arm swapped for the dual hole arm. 3rd link is the adapter plate to use your current 2 bolt brake caliper mount.
http://www.partsmike.com/index.php/p...knucklearm-kit
http://www.partsmike.com/index.php/p...high-steer-arm
http://www.partsmike.com/index.php/p...-gm-to-cj-pair
Did they put a traction bar in the rear? if not, that will be the next thing you will want to add before you start having axle wrap issues and are busting ujoints
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #14 of 25 Old 09-03-2019, 04:35 PM
KevinCJ7Jeep
1981 CJ7
A drop pitman arm might help too.
KevinCJ7Jeep is online now
post #15 of 25 Old 09-03-2019, 07:29 PM
Rtracy2001
You would think so, but from personal experience, it doesn't.
