Spring and Shackle Questions - JeepForum.com
 9Likes
  • 5 Post By Renegade82
  • 1 Post By BagusJeep
  • 1 Post By BrutusBlue
  • 1 Post By RARECJ8
post #1 of 13 Old 06-22-2021, 08:12 PM Thread Starter
InjectedCJ7
InjectedCJ7's Avatar
1978 CJ7
Iím looking for thoughts, from the Jeep experts here, on my springs and shackles on my 78 CJ7. Let me start by saying Iím not having any handling issues whatsoever. My Jeep tracks well, and seems to ride well, given what it isÖ All of the suspension work was done by the PO, and quite honestly, Iím not sure how much is stock and how much has been changed. My shackles have pretty thick side plates, with a welded in center bar (aftermarket?). The bolt center to center is approximately 4Ē. I know I have body lift spacers, ~1Ē or so, but do I have a chassis lift? Also, my front, pass side spring has a leaf that looks slightly out of position (see pics). Is this a big deal? Can it be repaired? I canít really tell if the bushings are in need of replacement. Is there a good way to tell? If any other pictures would help, I can supply them. Thanks in advance for your thoughts!
John
74F434DF-4E96-4AD8-8C1A-00F7F293CC1F.jpg   59C52BE5-712E-422C-BA7B-CA62964BABDF.jpg   E7B8DDDE-5B31-4FB0-97C2-2AFDA514F38C.jpg   B3A9DF5C-6B69-45E1-891C-51B425FF37B2.jpg
InjectedCJ7 is offline
post #2 of 13 Old 06-22-2021, 09:31 PM
Renegade82
Renegade82's Avatar
1982 CJ7
Yes, those are aftermarket shackles and they give you about 1/2" of suspension lift as well as more flex. Factory shackles were 3" bolt to bolt. Your bushings look to be poly so that's a good thing. Jack up your Jeep by the frame while you watch the springs and shackles. They should move as the springs droop. If not your shackle bolts may be a bit too tight. The nylock nut only needs to be around 20-25 ft/lbs so that your suspension can cycle, which gives a smoother ride.
While your Jeep is suspended with the tires just starting to want to leave the ground you should be able to take a hammer and tap that leaf back into place. It's not out enough to hurt anything, they do move slightly in certain situations during full droop but the clamp keeps them from going too far out of alignment.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #3 of 13 Old 06-23-2021, 08:31 AM Thread Starter
InjectedCJ7
1978 CJ7
Thank you, Renegade82! Thatís very helpful information. Much appreciated!
John
post #4 of 13 Old 06-24-2021, 02:51 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The shackle length is not a big issue. You will lose a little bit of caster. They are only 1" longer than stock and are indeed much more substantial.
The springs themselves are also not stock. They look pretty nice.
However, the bolts should protrude through a Nyloc at least 1 1/2 threads to get that locking action. Those do not look like they are.
They should also be greasable as those IMO horrible plastic bushings have no give and need to be greased to slip around.
It also looks that the bottom bolts have been over torqued and bent the shackle. The shackle bend is nothing to worry about, but I would certainly check out those bolts and torques and grease.
InjectedCJ7 likes this.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #5 of 13 Old 06-24-2021, 07:21 AM Thread Starter
InjectedCJ7
1978 CJ7
Thanks BagusJeep! Iíll get a new set of bolts and Nylocs. I pressed on the bushings with a screwdriver, and they feel soft, like they are rubber. Might be best to just replace all the bushings, while Iím at it. Is there a specific brand, or type of bushing you recommend?
John
post #6 of 13 Old 06-24-2021, 05:48 PM
BrutusBlue
1982 CJ7
If you are considering greasable shackle bolts and new bushings then you will need to know what size bushing you have now so you can order the correct size set. There two different bolt sizes. The bushing and greasable bolt sets usually come with a metal sleeve that inserts inside of the bushing that will prevent you from over tightening the bolts, on most shackles.
As far as moving your leaf back in place, which doesn’t look too necessary in my opinion, be careful when you tap the leaf over. Hard smacks with a 4lb hammer while the leaf is under load can cause the plastic spacers in between your leafs to split in half and come out.
BrutusBlue is online now
post #7 of 13 Old 06-24-2021, 06:29 PM Thread Starter
InjectedCJ7
1978 CJ7
As far as moving your leaf back in place, which doesnít look too necessary in my opinion, be careful when you tap the leaf over. Hard smacks with a 4lb hammer while the leaf is under load can cause the plastic spacers in between your leafs to split in half and come out.
Thanks BrutusBlue. What is a good source for the greasable bolts and bushings? I took the weight off the spring and tapped the leaf over a bit. I donít think I damaged the spacers, but Iíll take a look. Thanks for the heads up on that.
Regards,
John
post #8 of 13 Old 06-25-2021, 12:08 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Interesting that they are soft with a screwdriver. Elastomeric bushings do not need greasing so you need to sort out what you actually have and whether it is serviceable.
They do not look stock so measure carefully, work out what they are, what they should be, and have a look around. If you can work out the make of spring, that would be helpful.
post #9 of 13 Old 06-25-2021, 09:30 AM Thread Starter
InjectedCJ7
1978 CJ7
Good points. I think I will pull one of the bushings out to measure and identify. I believe that if I jack up the frame just enough to take the load off the wheel, I should be able to remove one shackle safely, correct?
John
post #10 of 13 Old 07-25-2021, 11:50 AM
thisoldjeep
Correct.
thisoldjeep is offline
post #11 of 13 Old 07-26-2021, 06:23 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
John
for this sort of maintenance we simply place a bottle jack between the leaf near the shackle and frame to take up the load. YMMV. good luck.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
Facebook: Hillís Angels 4x4 Club
RARECJ8 is offline
post #12 of 13 Old 07-27-2021, 06:26 AM
Jim1611
Jim1611's Avatar
There is not sleeve on the CJ bushing sets on any aftermarket shackles that I know of. CJ bushings are 1" o.d. with a 1/2" hole and with a 1/2" bolt, as is almost always used, there is no room for the sleeve. It's the YJ bushings that use the sleeve. Those bushings are 1 1/4" O.D. with a 3/4" hole. The steel bushing is 3/4" o.d. with a 1/2" hole. This is one of the advantages to the YJ style spring swap that I really like. If you want some greaseable bolts I have them, just pm me.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #13 of 13 Old 07-27-2021, 11:19 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Just finished up YJ conversion up front. Some hassles moving the front mount forward and wider. Rear fixed shackle hangers was cut off and new one welded in place. This is SOA application. Rubicon express makes pax for SOA specifically. They offer two types of YJ bushings, generally the small or large depending what u need, etc. took some effort but cane out nice. Now to finish the rear pack nightmare. .
DC689581-AC65-4691-BBA8-53543E6B2CA4.jpg   FD040D13-C90A-4394-86C5-7EECA4616C22.jpg   EF189510-6C4E-44F2-B735-95E6F95C70EE.jpg   0B0E5134-F14A-4737-B0F1-05244CBDAB56.jpg
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
