Sprayed U-Pol Raptor this weekend - JeepForum.com
post #1 of 42 Old 10-27-2008, 01:21 PM Thread Starter
VACJ7
VACJ7's Avatar
Turned out very nice and thought I would share. Thanks to all those that said this was easy to spray and helped sway my decision!
Sorry for not being click free...
http://members.cox.net/vacj7/Bedliner.htm
VACJ7 is offline
post #2 of 42 Old 10-27-2008, 01:25 PM
j33pman
j33pman's Avatar
Wow , nice Job.
and click free
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #3 of 42 Old 10-27-2008, 07:15 PM
stephens_cj5
stephens_cj5's Avatar
1981 CJ5
Very nice and clean. I'm considering using this underneath and inside my tub and wheel wells.
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline
post #4 of 42 Old 10-27-2008, 07:25 PM
CJman77
1977 CJ7
Okay now let me get this straight. You spray this stuff All over the bed with the pneumatic spray gun that comes with the kit? And it is easy to get on that evenly?
CJman77 is offline
post #5 of 42 Old 10-27-2008, 07:29 PM
mcmud
1983 CJ8
Looks OUTSTANDING!
mcmud is offline
post #6 of 42 Old 10-27-2008, 07:30 PM
Lawless_Jeep
Lawless_Jeep's Avatar
Wow, that turned out very nice. That's exactly what I want to do to mine. Thanks for sharing.
Jeeps are sorta like cats, but tend to have more than just nine lives.
Lawless_Jeep is offline
post #7 of 42 Old 10-27-2008, 08:12 PM
hookntail
hookntail's Avatar
1979 CJ7
so when you are masking that jeep off, how do you get clean lines where you tear the tape. I think that i saw the guys at Rhino lining use a tape that had a small wire in it that cut the liner like clay. I still dont understand how that works.... Im ready to do mine but still have a few questions...
hookntail is offline
post #8 of 42 Old 10-27-2008, 09:10 PM Thread Starter
VACJ7
VACJ7's Avatar
Yes sir... it really was easy and I have never attempted anything like this before. I was a little nervous when I got started but after a couple of minutes I was rolling along...
VACJ7 is offline
post #9 of 42 Old 10-27-2008, 09:15 PM Thread Starter
VACJ7
VACJ7's Avatar
After the last coat I waited about 30 minutes (it was still a little tacky) and then started removing tape from the bolt holes. That was easy... they came right out. I then moved on to the edge tape. I pulled the tape back on itself and away rom the edge as I removed it and it separated with the clean line. It did not take off any of the bedliner. and I had a lot of material on the tape. Some places so much you could not see the tape edge but it seprated beautifully.
And all I used was blue painters tape and a lot of it. Full roll plus some....
VACJ7 is offline
post #10 of 42 Old 10-27-2008, 09:16 PM
imtheant
Looks great just curious what made you pick this over Herculiner or others?
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline
post #11 of 42 Old 10-27-2008, 09:23 PM Thread Starter
VACJ7
VACJ7's Avatar
I had read good things about it here and I liked the fact that it came with the gun and easy to use bottles that attached to the gun.
VACJ7 is offline
post #12 of 42 Old 10-27-2008, 09:31 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
That looks very nice.
Any chance you can get an up-close pic so we can see the texture?
Pacfanweb is offline
post #13 of 42 Old 10-27-2008, 09:47 PM
craigb86
What did you do with all the bolt holes for like seats and such? Did you use ear plugs or golf tees to plug them?
Craig
craigb86 is offline
post #14 of 42 Old 10-27-2008, 10:03 PM Thread Starter
VACJ7
VACJ7's Avatar
Here are some very close up shots. The flash kinda makes it hard.
http://members.cox.net/vacj7/Upol_close.htm
I used a combination of golf tees and tape. What I found worked really well was taking a golf tee and wraping it in tape. Made a nice snug fit in some of the larger holes and made it simple to remove with a slight twist.
VACJ7 is offline
post #15 of 42 Old 10-28-2008, 08:02 AM
243
243's Avatar
1978 FSJ Cherokee
I sure wished they had it in white, light gray or tan, it's two dang hot down here to sit in a black anything!
Dave's 78 Build
243 is offline
The Upol Raptor sprayed, prepping for Paint SlikRic Jeep CJ Forum 20 03-24-2011 10:17 PM
Does anyone have pics of UPOL Raptor sprayed in on less than perfect interiors? hookntail Jeep CJ Forum 7 12-11-2009 11:51 AM
Sprayed TPC Firemist Metallic this morning... 243 Jeep CJ Forum 4 09-20-2009 01:56 PM
Great Stuff foam insulation sprayed into frame!? sdem6442 Jeep CJ Forum 16 09-08-2009 05:04 PM
U-Pol Raptor CJ Runner Jeep CJ Forum 0 06-01-2009 07:00 AM
