Spray glue on underside of hood 😕 - JeepForum.com
post #1 of 10 Old 02-18-2020, 07:47 PM Thread Starter
weider1717
Previous owner installed good insulation that I didn’t like trying to remove it. Any suggestions on the actual glue itself to get that off? Thanks
763E8900-A8B0-45BD-8142-78064292EFF6_1582080335459.jpg   34139F7A-6A37-4CB3-B9FE-F0CD4DDECB05_1582080388892.jpg
weider1717 is offline
post #2 of 10 Old 02-18-2020, 08:07 PM
ddawg16
ddawg16's Avatar
Naptha.....or Kerosene.....or a bunch of "Goof Off"
ddawg16 is offline
post #3 of 10 Old 02-18-2020, 08:17 PM
kd7oir
kd7oir's Avatar
1977 CJ5
I'd try a heat gun and putty knife. If paint isn't an issue I'd take the hood off and use oven cleaner or acetone.
Shawn
Shawn
kd7oir is offline
post #4 of 10 Old 02-18-2020, 10:42 PM
258
* DRY ICE
- Blasting, should come right off. (silver part)
- FYI: If you ever want to remove decals, this is how.
Goo Gone/Acetone/Lacquer Thinner (adhesive)
- use a plastic scrapper like they use to apply window tint so you doesn't damage the paint.
Good Luck
258 is offline
post #5 of 10 Old 02-19-2020, 12:25 AM
uw91
uw91's Avatar
Originally Posted by 258 View Post
* DRY ICE
Good Luck
Would an eraser wheel do the trick??? I didn't try on my hood adhesive.
PS: I gave in and simply bought new hood insulation from Collins Bros. (through eBay for cheaper shipping)
PNW Represent
uw91 is offline
post #6 of 10 Old 02-19-2020, 12:38 AM
258
If you gave in, you can gently sand down the needed area and get "3M Super 77 Spray Adhesive". It is an easy to use High Tack spray in a can. Simply spray on the under-hood area (tape off area) that you sanded and on the underside of New Hood Insulation. Let it tack dry and carefully stick it on. Use one of those small rollers afterwards; like for applying wallpaper, and roll it nice and flat. You should be fine!
Make sure you use newspaper or something along the edges for over spray. You want to make sure the edges are especially sprayed well.
258 is offline
post #7 of 10 Old 02-19-2020, 04:30 AM Thread Starter
weider1717
Thanks all for the great ideas. A 1978 wouldn’t have came with any insulation correct?
post #8 of 10 Old 02-19-2020, 05:19 AM
keith460
keith460's Avatar
I think they started adding them in 1981 or 82 with the Laredo, Limited models as part of sound proofing option.
Collins Bros and eBay sell this one that is made by REM Auto Inc. Found here: https://www.remautoinc.com/index.php
1984 CJ-7 Renegade
keith460 is offline
post #9 of 10 Old 02-23-2020, 09:00 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
i put one on my CJ a few years back but took it off again due to concerns that it might hold too much heat in the engine compartment and make me run hotter.... Is this a valid concern? It was quieter with it on, but now I live in AZ where it can get pretty toasty......
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #10 of 10 Old 02-24-2020, 08:43 PM
ddawg16
ddawg16's Avatar
Naw....it won't make it run hotter....the underside is open and all the air goes down that way. The only way you 'might' get it to run cooler is having vents in the hood. But if you need them to run cooler....you have other issues.
I do see an advantage in the winter....it would keep the heat in the engine bay a little longer.
ddawg16 is offline
