sitting on tailgate? - JeepForum.com
 2Likes
  • 2 Post By jeepdaddy2000
post #1 of 13 Old 09-09-2019, 06:42 PM Thread Starter
shok47
1983 CJ7
Hi guys,
With your stock tailgate down, do you sit/stand on it without worry or is that too much weight?
Thanks
shok47 is offline
post #2 of 13 Old 09-09-2019, 07:04 PM
MrButterfield
MrButterfield's Avatar
1976 CJ5
I did once. Wont do it again. Im not a big guy but i noticed how much strain it put on the little chain tabs.
MrButterfield is offline
post #3 of 13 Old 09-09-2019, 07:22 PM
jay-h
I do on my CJ2A. Never really noticed an issue (I'm about 170#)
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 13 Old 09-09-2019, 07:30 PM
Axhammer
Axhammer's Avatar
I guess it depends on the year model you are talking about. My 1985 CJ-7 has cables that support the tailgate just fine. I sit on it sometimes when I’m bolting the hardtop down. The 1986 model I bought new was the same design. Back then loaded and unloaded Pontiac 428 and 455 blocks into the back of my Jeep alone. It was everything I could do to lift the block high enough to lay it on the tailgate by myself. Once I had the block on the tailgate I could slide it into the back, so I could deliver it to the machine shop. A bare Pontiac block weights about 190 lbs.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is online now
post #5 of 13 Old 09-09-2019, 08:23 PM
MetalMountainGoat
MetalMountainGoat's Avatar
I've never sat on mine, but my tub is cracked right beside one of the hinges, so I'm not about to test it.
MetalMountainGoat is offline
post #6 of 13 Old 09-09-2019, 09:24 PM
MikeyDeezy
MikeyDeezy's Avatar
1980 CJ7
I was suspect to doing this very thing at first, especially because my tailgate must be aftermarket since it does not have the stamped Jeep name logo. I did however inspect all of the mounting points of hinges and supports, with it all being solid and adjusted properly. I sit comfortably and confidently now with either my 6 year old son (65lbs) or my 4 year old daughter (50lbs), and I’m coming in at 235lbs. I expected to see the tailgate bow or wince, but solid. So I just say inspect it closely, and don’t Invite Greg Louganis to the BeerFest BBQ.
Sent from my iPad using Tapatalk
MikeyDeezy Sez...Take ‘er E-Z and Keep it Breezy!
MikeyDeezy is offline
post #7 of 13 Old 09-10-2019, 01:02 AM
ddawg16
ddawg16's Avatar
No issues with my CJ7
ddawg16 is offline
post #8 of 13 Old 09-10-2019, 06:50 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Partied off the tailgate for years back in the day. Two grown adults sitting on it with no issues.
WindKnot and pedal2themetai like this.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #9 of 13 Old 09-10-2019, 08:28 AM
cJAY904
I use mine as a bed extender often. I put two large coolers side by side, length-way and tie them so they don't fall off the back. Then I drive long distances with them in that location. I have never seen any signs of stress.
cJAY904 is offline
post #10 of 13 Old 09-10-2019, 08:41 AM
keith460
keith460's Avatar
No problems even with my weight of 250lbs or 1/8 of a ton, sitting on the tailgate. I even sit on the CJ-7 tailgate workbench I built in my garage that is attached to the wall sometimes. Never an issue or concern.
1984 CJ-7 Renegade
keith460 is offline
post #11 of 13 Old 09-10-2019, 08:50 AM
Fourtrail
1974 CJ6
Double wall CJ-7 tailgates are fine to sit on being double wall, CJ-5 gates like to bend, if you want to sit on a '5 most will run a piece of round bar stock through the top of the tailgate to support it better.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #12 of 13 Old 09-10-2019, 12:41 PM Thread Starter
shok47
1983 CJ7
Thanks guys, sounds good. I have a YJ tub and just fiitted the CJ7 tailgate on. Didnt have mounting brackets for the tub side so I just cut 2 square pieces from the the leftover steel plate for the hinge reinforcement behind the body and used (2) 1/4" bolts to connect to body, with about 1 inch sticking above the wheel well and another 1/4 bolt through this protruding part to hold the cable. It moves more than I am comfortable with. I wanted to use the existing 2 holes/ welded nuts on the driver side were the YJ door jam was mounted.
Really dont want to sped $100 just for those brackets.
Now I am thinking I just drill directly into the wheel well and use those square plates as reinforcements.
Can you guys post pics of your body side hinges?
Thanks
shok47 is offline
post #13 of 13 Old 09-11-2019, 09:46 AM
bob4703
1974 CJ5
Mine came prebent so I have no qualms about sitting on it. I replaced the rusty chains and made sure the new ones were rated at least 250#.
Paved roads are prime examples of government over spending!
bob4703 is offline
