Should I replace door glass seal ? - JeepForum.com
post #1 of 17 Old 11-15-2019, 07:09 PM Thread Starter
agear
I've been working on my full hard doors. Messing with the first one got a little ugly from binding when trying to crank up the window with the new glass edge seals I put in. My other door's seals are still in the door and I'm wondering if it's worth it to replace . They're dry and thinned out some but I dont know if it's worth it. What do you think ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is online now
post #2 of 17 Old 11-15-2019, 09:06 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
I just replace ALL the seals on my doors. Its a little harder to close the windows. I would recommend you replace them on the second door.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #3 of 17 Old 11-16-2019, 12:51 PM Thread Starter
agear
Why do you say so ?
agear is online now
post #4 of 17 Old 11-16-2019, 01:15 PM
WJ60
WJ60's Avatar
Seals are there to prevent water from getting into the door interior. If the seal has degraded then rust could be in your future, as well as damage to components. New seals will break in fairly quick so it's wise to install them as needed.
WJ60 is offline
post #5 of 17 Old 11-16-2019, 02:27 PM Thread Starter
agear
The doors have gaps in the bottom where water can get out. What do the seals do for sealing out the cold outside or sealing in the a/c in the summer ? Is that negligible ?
agear is online now
post #6 of 17 Old 11-16-2019, 03:57 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
More water getting inside is not good. As WJ60 says, the seals breakdown and the pieces can clog the drain holes. The water now collects inside and rusts out the door. My point was if youíre going to trouble to change one, change them all.
Tim
87MJTim is offline
post #7 of 17 Old 11-16-2019, 04:57 PM Thread Starter
agear
More water getting inside is not good. As WJ60 says, the seals breakdown and the pieces can clog the drain holes. The water now collects inside and rusts out the door. My point was if you’re going to trouble to change one, change them all.
Ok. I have the seals taken out as we speak. I'll follow up if I have trouble again
agear is online now
post #8 of 17 Old 11-16-2019, 05:48 PM
WJ60
WJ60's Avatar
There are penetrations made for water to drain but so far as cold or hot air entering the the vehicle thru the doors is prevented by a barrier between the door panel and the door. I'm including a picture of one of my doors that I added that barrier to as it had been removed by a PO.
WJ60 is offline
post #9 of 17 Old 11-16-2019, 06:26 PM Thread Starter
agear
I hate resealing the hard doors. Yet again the window is binding on the seal. The seal doesnt sit in there even either
agear is online now
post #10 of 17 Old 11-17-2019, 09:24 AM
Axhammer
Axhammer's Avatar
What brand are the glass seals you are installing on your steel doors? Did you replace both inner and outer? Iíve had problems with aftermarket seals and weatherstripping on cars over the years. They are never as nice as the OEM parts were.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #11 of 17 Old 11-17-2019, 09:34 AM
Axhammer
Axhammer's Avatar
I like that idea. That vinyl barrier is thicker than the plastic sheet from the factory, so as long as the panel still goes on OK, Iím thinking thatís the way to go.
Axhammer is offline
post #12 of 17 Old 11-17-2019, 10:57 AM
WJ60
WJ60's Avatar
The panel actually fit the door tighter with the new material than it does with the original. I ended up installing it in all the other doors and the rear hatch. I used 3M double sided tape as opposed to the adhesive the factory used. The previous picture shows the liner being installed with the adhesive but it was a pain so I stripped it off and used the tape.
WJ60 is offline
post #13 of 17 Old 11-17-2019, 11:37 AM Thread Starter
agear
What brand are the glass seals you are installing on your steel doors? Did you replace both inner and outer? I’ve had problems with aftermarket seals and weatherstripping on cars over the years. They are never as nice as the OEM parts were.
I'm using crown or omix
agear is online now
post #14 of 17 Old 11-21-2019, 03:40 PM Thread Starter
agear
I finally git the sesl installed and it working. This new seal I just go in was a lot thicker (same brand crown) and harder to put in but once I got it all in it was pretty nice. I think the seal was my problem and probably on the other door too. I need s new handle rod clip and then I'll be done . Shew
agear is online now
post #15 of 17 Old 11-22-2019, 01:36 AM
MetalMountainGoat
MetalMountainGoat's Avatar
I just rebuilt my doors with a Fairchild industries kit. The windows were super hard to roll up and down at first, but after spraying the seals with some windex, and rolling the window up and down about 10 times, they loosened up. They are still tighter than before, but there is defiintely no water or air getting through them.
MetalMountainGoat is offline
