Shake when letting out the clutch - JeepForum.com
 1Likes
  • 1 Post By MrButterfield
post #1 of 10 Old 05-04-2021, 04:20 PM Thread Starter
svu0312
I have a 1979 CJ7 with the 304 and a 3 speed transmission. I have an issue with the jeep shaking/jerking when letting out on the clutch only after it warms up. When this happens I can sometimes press the clutch pedal in and rev the engine and it works perfect at that moment but the next stop I am right back to the same problem. It feels like the Jeep is going to stall but the shaking/jerking is enough to bounce the vehicle. Has anyone experienced this and found a solution to their problem?
svu0312 is offline
post #2 of 10 Old 05-04-2021, 05:18 PM
MrButterfield
MrButterfield's Avatar
1976 CJ5
Clutch Chatter. My 76 CJ5 did this. Its one or more of the following: worn out clutch assembly, improperly worn clutch assembly, bad transmission mount/torque stud bushing, or worn motor mounts. In my case it was all the above. Replaced all of it, no more chatter.
Sent from my SM-G960U using Tapatalk
JEEPFELLER likes this.
MrButterfield is offline
post #3 of 10 Old 05-04-2021, 06:31 PM
shadoow
you may have an oil leak somewhere (valve cover, rms maybe) causing the clutch disc to get oil on it. At least that's what I found when my clutch was doing the same thing; chatter when warmed up, works fine when first driving.
shadoow is offline
post #4 of 10 Old 05-05-2021, 06:03 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Also include bad/broken body mounts.
Start by trying to lift the body at mounts forward of the t case. Pay close attention to the body around the clutch linkage.
Lift the engine slightly by the pan and see if one of the motor mounts separates.
Remove and inspect the transmission mounts.
Insure the skid plate is tight.
Insure the clutch linkage is operating properly.
Repair any discrepancies.
If all is good, then you have a clutch issue.
Disassemble the clutch. Hot spots on the flywheel and pressure plate are signs of riding the clutch and can cause jutter.
Insure there is no on contamination (oil) on the assembly. If so, you will need to fix the leak.
While you can inspect the rest of the components, I would simply replace the assembly, being sure to turn the flywheel.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #5 of 10 Old 05-05-2021, 06:53 PM
John Strenk
John Strenk's Avatar
1976 CJ5
I had the same issue, thought it was the clutch but turned out the bolts holding the tranny to bell housing was loose.
It allowed the tranny to become a little tilted and chatter.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #6 of 10 Old 05-05-2021, 08:07 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Have you been yanking and snatching you Jeep----burning the clutch/ flywheel/ pressure plate, as in pulling a big truck out of a ditch or attempting to pull a tree/ bush out of the yard for Mama?
----JEEPFELLER
JEEPFELLER is offline
post #7 of 10 Old 05-06-2021, 06:58 AM
Anotherusername
You might check the clutch linkage. That bellcrank lever that goes between the clutch pedal and the throwout lever is pretty wimpy. I've had to replace mine twice in the last 20 years.
Anotherusername is offline
post #8 of 10 Old 05-07-2021, 05:52 AM Thread Starter
svu0312
Thank you for all the info. I hope to have some time this weekend to check out some of these possibilities.
svu0312 is offline
post #9 of 10 Old 05-07-2021, 08:42 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Well
Overlooked?
Maybe not knowing what to check?
Not really checked well?
What about checking the "U" joints for some sloppiness in between them?
----JEEPFELLER
post #10 of 10 Old 05-09-2021, 10:31 PM
ddawg16
ddawg16's Avatar
All suggestions above good (almost all)
Also check to make sure your bellhousing bolts are tight. Happened to me....and I had exactly the same symptoms.
ddawg16 is offline
