Shackle Reversal - JeepForum.com
 6Likes
post #1 of 16 Old 01-17-2020, 09:40 PM Thread Starter
dallasalice
1983 CJ5
Shackle Reversal
Looking to do a shackle reversal on my 83 CJ5 any recommendations on which is the best? Bolt on or Weld, Any certain brand any better?
dallasalice is offline
post #2 of 16 Old 01-18-2020, 06:55 AM
pedal2themetai
1956 CJ5
No such thing as shackle reversal on a JEEP. You have to do extension .. shackels have to move so welding is NO. check out your local 4X4 shop for parts.
pedal2themetai is offline
post #3 of 16 Old 01-18-2020, 08:44 AM
Fourtrail
1974 CJ6
I like the way the w.f.o. kit puts the shackle through the frame, but you also have to convert to yj springs if you haven't already. Keeps everything up nice and tight to the frame in the front for better approach angle and doesn't give you extra lift in the front. Kit requires welding. For a pure bolt on kit, i like the one from m.o.r.e. their stuff all seems to be hd and well thought out.
https://www.wfoconcepts.com/pr/CJ-Sh...ox-Mount/18881
https://mountainoffroad.com/products...anger-76-86-cj
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 16 Old 01-18-2020, 10:15 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
On early CJ's, shackle reversals could be done by either purchasing an M38 frame (as I did) or knocking off the existing shackle mounts and remounting them on the opposite side. If memory serves, this can be done with later models as well. There will be a serious caster issue that will have to be addressed, as the rear shackle mounts will be under the frame instead of through it, pushing the rear of the spring down.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is online now
post #5 of 16 Old 01-18-2020, 12:59 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
What are you talking about?
The OP is referring to reversing the shackles on the front spring of their jeep so that the front has the fixed mount, and the rear is the movable mount (shackle).
The two options are either bolt on front fixed mount, or weld on.
Hoss
STJP likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #6 of 16 Old 01-18-2020, 05:49 PM
CSP
I'm guessing that you're thinking of a shackle flip, like what is done on the rear of square body Chevy trucks to gain lift at the rear.
This is not what the OP is asking about.
pedal2themetai likes this.
CSP is offline
post #7 of 16 Old 01-21-2020, 02:38 PM
ddawg16
ddawg16's Avatar
What is the objective? A better ride with lifted springs?
I had a buddy who did one.....then later went SOA.....no comparison....SOA with stock springs worked much better.
ddawg16 is offline
post #8 of 16 Old 01-21-2020, 09:48 PM
jeepdaddy2000
1971 CJ5
Reverse shackles articulate better when moving forward, as the spring compresses to the rear instead of having to push into an obstacle to get the springs to flatten. I've noticed a difference when negotiating sharp objects or dropping into a pothole.
They also tend to steer better (less lateral shackle movement) as the anchor bushing is closer to the steering system.
The stated downfall is supposed braking issues (springs compressing under braking), but I have never experienced any problems.
Thomas Payne
post #9 of 16 Old 01-22-2020, 01:02 AM
ddawg16
ddawg16's Avatar
True....if your lift is not too much.
But....if you have 5-6" of lift with springs on a shackle reversal...well....it's not going to perform as well as SOA.
Key feature of SOA.....you can use stock (or custom with no lift) springs. This puts the axle at a neutral position giving the ideal steering geometry
Additionally, SOA gives about 6" of lift....and a much greater range of travel than a shackle reversal will. My shocks have a 16" travel. I haven't used all of it yet, but I'm willing to bet a shackle reversal won't come close.
I'm using stock Wrangler springs. Hence, I moved my front hangers forward about 2". I'm not running a stabilizer shock at the moment....and I don't have any fwy driving issues....even at 80+. (speedo only goes to 85...I will never admit I exceeded that)
ddawg16 is offline
post #10 of 16 Old 01-22-2020, 09:41 AM
BrutusBlue
1982 CJ7
Dalllasalice,
Without knowing your entire setup or intended use you will get an educated guess at best on which way is better. SRS have a place but without knowing the rest of the story answers are of zero benefit. What are plans?
BrutusBlue is offline
post #11 of 16 Old 01-22-2020, 09:59 AM
cJAY904
Mine came with a Warrior Products Shackle Reversal System already installed. I do not know what the PO was trying to accomplish, but I think he met his objective. The steering in my CJ7 is great. I am running 35" and I can drive at 65+ MPH with not worries. I can track straight with no "white knuckle" driving.
I have done some rather aggressive breaking, and did not have any issues. I hope this helps/.
cJAY904 is offline
post #12 of 16 Old 01-22-2020, 11:53 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Just FYI, one 4x4 shop owner I know won't install SRS after witnessing a CJ crash badly in MOAB on a steep descent. He said the nose of the Jeep dove down enough to cause the rear axle to hop, and the driver lost control. Other Cjs with regular suspensions negotiated the descent with no problems.
I'm not trying to dissuade you, because there are advantages, as stated. But the braking issue would be enough of a concern to prevent me from doing it.
Matt
ddawg16 likes this.
Matt1981CJ7 is offline
post #13 of 16 Old 01-30-2020, 09:48 PM
CSP
Worked much better. Not going to perform as well as SOA. Could you possibly be more vague/vanilla?
Comparing the characteristics for reverse shackle that jeepdaddy listed to how a spring over rig handles when wheeling is about as apples vs oranges comparison that you could make. The reasons to go with either aren't even on the same radar screen.
CSP is offline
post #14 of 16 Old 01-31-2020, 10:30 AM
ddawg16
ddawg16's Avatar
If you're going accuse me of being vague, at least quote all of what I said, not just part of it.
SR with no lift is really no better than stock setup. Springs are flat...as the axle moves up or down, it moves forward ever so slightly. SR with lifted springs does solve the issue of rough ride by allowing the axle to move back when coming under compression. But it you use stiff springs, the benefits are somewhat negated.
A Shackle Reversal is also expensive in relative terms
SOA with stock flat springs is one of the most economical lifts you can do while getting a great ride and lots of travel. When I did mine, I had the front end aligned before I welded to top spring perches.
So....to make this less 'vague'....
Shackle Reversal
1. Modify Rear Hanger
2. Weld Front spring hangers.
3. Lifted springs
4. Longer shocks.
SOA with stock springs.
1. Weld new spring perches
2. Longer Shocks
ddawg16 is offline
post #15 of 16 Old 01-31-2020, 08:42 PM
CSP
Umm, nobody asked for a "how to". You really don't know your audience.
The accusation of vague/vanilla is because you never said what SOA "worked better" at, or "performed as well" at. It had nothing to do with the rest of your post, thus that was deleted. You know, intentional like.
You also made these claims with zero knowledge of the OP's desired end result. I'm fairly certain that his question wasn't shackle reversal vs spring over or which to pick and why.
Not every one wants a spring over Jeep and doing it correctly is far from economical. Your two steps are hardly all that it takes. Add longer driveshafts, longer brake lines, anti-wrap bar for the rear, and the expensive part - steering (and not a drop pitman arm). Then there's the fact that if you're going that tall, it's usually a good idea to go wider especially if it's a CJ5.
CSP is offline
