Seal Leak Won’t Stop Leaking - JeepForum.com
 9Likes
post #1 of 35 Old 03-03-2019, 01:50 PM Thread Starter
Alabamacj71981
Alabamacj71981's Avatar
Help. I’ve got a transfer case (Dana 300) that has a front drive shaft yoke seal that keeps leaking. I’ve replaced it 4 times. I’ve tried different brands, etc. It leaks where the output shaft goes through the rubber dual lipped hole of the seal. The leak generates about 50mL each night. It stays at this same rate. Any ideas? The pic below is old (things are cleaner now) but is representative of the new seal install direction and location.
Karl
Alabamacj71981 is offline
post #2 of 35 Old 03-03-2019, 02:13 PM
lacscam
lacscam's Avatar
I can't tell from the picture, but when I replaced my seal, I put a thin skim coat of RTV on the outside of the seal. Additionally, I clean the splines and put a light coat of RTV on the splines as well.
Can you tell the source if the leak(splines, outside edge of seal, inside of seal)?
lacscam is offline
post #3 of 35 Old 03-03-2019, 02:28 PM
Boojo35
What does the surface of the yoke where it makes contact with the seal look like? Is it grooved or damaged in anyway?
John Strenk and trailhead2004 like this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #4 of 35 Old 03-03-2019, 02:41 PM Thread Starter
Alabamacj71981
I have used the recommended sand paper (doesn’t feel like sandpaper) to remove any issues and did not see anything on the outside of the yoke that would come into contact with the robber seal. This is where the leak is occurring. However, I might not have a trained eye for that sort of thing. I have tried single and dual lipped seals. I have tried lightly sanding for burrs. Also, tried greasing and not greasing the seal so I don’t fudge the lip of the seal when I slide in the yoke shaft.
I like that you guys are enlightening me that it could be the splines.
Thanks,
Karl
post #5 of 35 Old 03-03-2019, 03:31 PM
jtec
2014 JK Wrangler
issue is the seal against the yoke, often the yoke will get a grove over time and our offroading dirt, sand etc not a kind environment, there are sleeves that press onto yoke sealing surface.
The older jeeps - sure the yoke is correct for this application - one of the challenges working on older vehicles. I think redi seal is a trade name seal/sleeve kit.
jtec is offline
post #6 of 35 Old 03-03-2019, 03:39 PM
kovic
1983 CJ5
Before I tore my jeep down that was leaking on mine also. It was caused by my U joints vibrating so bad and ruining the bearings. May want to check the shaft for play, may need new bearings.
kov
80cj and Clicker01 like this.
kovic is offline
post #7 of 35 Old 03-03-2019, 03:51 PM
Boojo35
Speedy sleeve is a name I have used in the past. Not sure if they are still around. They made a lot of harmonic balancer repair stuff.
jtec likes this.
Boojo35 is offline
post #8 of 35 Old 03-03-2019, 03:52 PM
Boojo35
take pics of your yoke and post them if you do not have a trained eye.
Boojo35 is offline
post #9 of 35 Old 03-03-2019, 04:29 PM
Rsb201
Have you checked your transfer case vent?? A restricted vent will cause a seal to leak.
jtec likes this.
1986 CJ7 4.2 Weber T176 D300
Rsb201 is offline
post #10 of 35 Old 03-03-2019, 04:38 PM
trailhead2004
trailhead2004's Avatar
1980 CJ7
Question
I'm with Boojo on this one. My thought on a constantly leaking seal, especially after having replaced the seal a few times, is a grooved yoke surface. It only takes a little reduction in gland (?) diameter to reduce the seal lip pressure a lot.
Inspect the seal/yoke contact surface carefully for a groove. Do you have any pictures of the yoke when it's out of the TC?
"Johnny Cash, The Jeep in Black" Build Thread - Started 7 July, 2018
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #11 of 35 Old 03-03-2019, 08:45 PM Thread Starter
Alabamacj71981
Great feedback. Here are some responses in no specific order:
(1) I’ll take some pics of the yoke next weekend. I’ll be on travel tomorrow for the work week.
(2) I just replaced my drive shaft u-joints in front and back so they have no play. The front drive shaft is not spinning. Confirmed by taking boot off of shifters and sneaking a peak while test driving. It is currently in two wheel high. The front drive shaft is able to be wiggled a little with the front dive shaft where the little segment meets the longer segment. Not sure what is normal.
(3) my TC air vent tube, I just replaced. It should be nicely breathing.
(4) I hope I don’t need new bearings...
Sounds like I should buy a new yoke but I will definitely send pics to this thread to learn the eye for issues. I think I can also clean the splines better. I’ll also research the other solution mentioned above if that treatment can save money.
Real great feedback. Much appreciated!
trailhead2004 likes this.
post #12 of 35 Old 03-04-2019, 12:24 AM
LJameson
LJameson's Avatar
If it is in fact the yoke, you donít need to replace it. Repair sleeves are readily available that are made to address this issue.
1990 YJ
1976 CJ7
2001 TJ
LJameson is offline
post #13 of 35 Old 03-05-2019, 06:41 PM
importman
How much lateral motion, (up and down) does the output shaft have? If the output shaft bushing is worn the excessive motion can cause the yoke to stretch the seal and leak in a very short time.
Clicker01 likes this.
importman is offline
post #14 of 35 Old 03-05-2019, 07:01 PM
astjp2
speedi sleeve... and I had one that was leaking between the splines and the nut/washer, they make a seal washer for that. Tim
astjp2 is offline
post #15 of 35 Old 03-05-2019, 09:22 PM
kj.com
2005 KJ Liberty
have used speedi sleeve seal on full side trucks for over 25 years good deal looking back at pic looks as roller bearing how is yoke to spline fit slide on not move side to side or wiggle
kj.com is offline
dana 30 hp pinion seal still leaking Mark-318-IT ZJ Grand Cherokee Forum 4 02-10-2019 03:09 AM
Front inner axle seal experts needed - leaking after replacing AWheeler TJ Wrangler Technical Forum 11 10-15-2018 08:10 AM
Transmission Leak 42RE front pump seal? Skippynutz123 ZJ Grand Cherokee Forum 4 09-21-2018 01:51 PM
Front right CAD seal leaking Waternut YJ Wrangler Technical Forum 8 03-06-2018 11:20 AM
Rear main seal leak brownmk Jeep CJ Forum 34 02-04-2018 06:25 PM
