Rough Idle/Bad Timing? - JeepForum.com
 3Likes
post #1 of 29 Old 11-12-2019, 03:32 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Jeep runs a bit rugged at idle, which is between 650-800 depending on the day. It pops a bit from the exhaust. The second I run the RPM's up, it cleans up nicely. It runs strong at anything above about 900. MC2150, nuttered, and recent Team Rush. When I replaced the plugs during the TR, I took pictures of them, they all looked pretty similar. Pictures attached
Could this be timing or 2150 adjust that is needed? Again, I will stress that it runs pretty well, but it would be nice to have it purr at idle as well.
Thanks for any thoughts
cpadget is online now
post #2 of 29 Old 11-12-2019, 05:10 PM
uptillnow
uptillnow's Avatar
What is your jetting on this MC2150? It is rich, or weak spark not burning efficiently.
Timing? 10-14 BTDC at 600 RPM idle?
It does look like late timing, although these Motocraft distributors have what I call "emissions timing". This means that you may have good initial timing, but the distributor total advance is no more than 18 degrees and most of the time less than that.
A way to check your total advance is with a dial timing light.
Or
You can check your advance slots for the 13R-18R slots, wanting the advance arm in the 18R slot. see pictures
UTN
EDIT: These are Matt's pictures that I use a lot. Thank you Matt.
uptillnow is online now
post #3 of 29 Old 11-12-2019, 05:32 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
So is it likely that mine is in the 13R slot? I don't have any reason to believe that was ever changed. I am not sure on the jetting on the carb. In Phoenix, at 1000 ft elevation, what jetting am I looking for?
post #4 of 29 Old 11-13-2019, 04:57 AM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
Do you still have the stock Carter BBD carb? Drippy carb maybe, clogged idle tubes? https://www.jeeptech.com/engine/carter.html
Terry Howe
'49 Willys CJ-3A
TerryHowe is offline
post #5 of 29 Old 11-13-2019, 05:48 AM
pedal2themetai
1956 CJ5
hi, the black looks like oil fouling. white is lean .. normal is lite brown. might try enriching up the mixture a little 1/4 to 1/2 out a turn and see what that does. My ranger was doing the popping thru the exhaust and I enriched it hole turn and it runs great now with no popping.
good luck
tim
pedal2themetai is offline
post #6 of 29 Old 11-13-2019, 07:43 AM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Terry, MC2150, no computer
post #7 of 29 Old 11-13-2019, 07:44 AM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
good luck
tim
Not being a motor guy at all, I have never seen a plug that was dark brown on one side and white on the other. I will play with the mix and see what happens
post #8 of 29 Old 11-13-2019, 08:11 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
cpadget,
It's normal for the plugs to color on one side but not the other. That's the side of the plug the fuel is burning on.
Your plug definitely looks rich. Have you adjusted the carb for the lean/best idle mixture?
The exhaust popping could be from loose manifold bolts. The 258 is notorious for that.
Matt
pedal2themetai likes this.
Matt1981CJ7 is offline
post #9 of 29 Old 11-13-2019, 08:52 AM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Matt, thank for the reply. I have not done any adjusts on it since install. I do have a small exhaust leak, down near the cat or muffler. I will check the manifold bolts and torque them appropriately. I assume playing with the mixture screws will be obvious in how it changes the idle?
post #10 of 29 Old 11-13-2019, 12:10 PM
Matt1981CJ7
1981 CJ7
A vacuum gauge comes in handy for adjusting the idle mixture. Connect it to a manifold vacuum source. Start with both mixture screws adjusted to 1 1/2 turns from lightly seated. Then adjust each screw equally until you get the highest steady vacuum reading.
Matt
post #11 of 29 Old 11-13-2019, 12:50 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Matt, I have read a bunch on here about hooking distributor up to Ported vs. Manifold. I believe I have mine hooked up to the ported on my 2150. Is this correct. Where else would it get hooked to, and why would you want it different?
post #12 of 29 Old 11-13-2019, 01:09 PM
Matt1981CJ7
1981 CJ7
I believe that's ported vacuum. The easy way to tell is if there is vacuum at the port at idle, then it's manifold vacuum. If not, it's ported.
I recommend running manifold vacuum advance. It will give you a cooler more efficient idle.
Matt
post #13 of 29 Old 11-13-2019, 01:38 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Thats what I read. So if I was to run that vacuum line from the distributor to manifold vacuum, would I run it to the 5 port CTO block coming off the manifold? Or where would I run it to?
post #14 of 29 Old 11-13-2019, 02:01 PM
Matt1981CJ7
1981 CJ7
No, don't connect it to the CTO. Here's is where I'd connect it.
post #15 of 29 Old 11-13-2019, 02:43 PM Thread Starter
cpadget
cpadget's Avatar
1983 CJ7
Got it. I will experiment with that
