Roll new OD forward? - JeepForum.com
post #1 of 7 Old 08-13-2020, 01:10 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Digging deep into the restoration requires a new speedo cluster. Old one is OEM 1981 and is afu. Have new omix Ada cluster and itís all at zero. Want to dial it fwd to match current dead odometer. This is NOT a roll back deal. Not now or ever for sale. Itís roll new unit forward to replace the old. Our state watches OD readings And how explain a old vehicle suddenly has zero miles?
How do resto mod guys do it?
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2 of 7 Old 08-13-2020, 02:27 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
They take them apart, on the instrument cluster you have to release the chrome bezel carefully with a large flat driver, remove bezel and glass and then unscrew the speedo head.
Twist the retaining spring clip on the back and push down, it holds the odometer. Once odometer is out you can adjust the reels and select the numbers.
Put it back together.
This is quite easy to do, I may have adjusted a few vehicles over the years to better describe their condition.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 7 Old 08-13-2020, 05:59 AM
bob4703
1974 CJ5
A call to the state regulatory agency will get you the how to info. You won't ask a question that hasn't been asked before.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #4 of 7 Old 08-13-2020, 06:20 AM
whollsee
1982 CJ7
Yep and the TSM has instructions and images as well. Be careful around the very fine tension coil spring.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #5 of 7 Old 08-13-2020, 08:58 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Call your department of transportation. They will have a registration process for the new odometer. My wife's Z3M had the speedometer replaced at 11K miles in California. When we purchased it, it came with a required state certificate that noted the change.
This would much easier and safer than disassembling the unit.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #6 of 7 Old 08-13-2020, 10:24 AM
4Low2G0
4Low2G0's Avatar
This is correct, then they issue a cert. noting it has been replaced.
Not a big deal, happens all the time.
Whats over that next ridge?
4Low2G0 is offline
post #7 of 7 Old 08-13-2020, 11:18 AM
Fourtrail
1974 CJ6
Take the old one apart and swap the odo reel into the new speedo.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
