Reuse 304 flywheel bolts?? - JeepForum.com
 1Likes
  • 1 Post By 80cj
post #1 of 9 Old 05-23-2020, 10:13 AM Thread Starter
wrangler0415
wrangler0415's Avatar
Hello there, just wondering if I should reuse my flywheel bolts with my new flywheel for the 304. They thread into the crank fine but when you put the flywheel on to the crank they seem to be quite hard to thread in. Possibly stretched??
wrangler0415 is offline
post #2 of 9 Old 05-23-2020, 10:27 AM
Axhammer
Axhammer's Avatar
If the bolts thread into the crankshaft fine without the flywheel then that tells me the threads are fine. The resistance is probably from the flywheel not being lined up perfectly. Lots of people reuse hardware when rebuilding engines, especially when itís a stock type situation. If itís a high performance type build, I lean towards replacing hardware under load.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #3 of 9 Old 05-23-2020, 10:27 AM
80cj
80cj's Avatar
1980 CJ5
A new set of bolts doesn't cost that much. Probably the best way to go.
Sparkybob likes this.
80cj is offline
post #4 of 9 Old 05-23-2020, 10:44 AM Thread Starter
wrangler0415
Just looking at the mr gasket kit for $20. I'll probably just go with the new bolts even though the 304 is basically the stock setup. Thanks guys
post #5 of 9 Old 05-23-2020, 09:05 PM
Bmann412
Bmann412's Avatar
1930
I just ended up using the stock bolts since mine were in good shape. I looked into the mr.gasket ones but read that they were a bit to long. I could be incorrect but just thought I should throw that it out there.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #6 of 9 Old 05-24-2020, 08:17 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I have done hundreds of clutch jobs (flywheels resurfaced) and have never replaced a flywheel bolt that wasn't missing or obviously damaged with zero failures. As stated above, sounds like a flywheel alignment issue.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #7 of 9 Old 05-24-2020, 05:41 PM Thread Starter
wrangler0415
It makes me think, I only tried bolting the flywheel on one way. Ill rotate it around and see if that helps the bolts thread in better. I have new bolts on the way just in case
post #8 of 9 Old 05-24-2020, 07:57 PM
Bmann412
Bmann412's Avatar
1930
Try running a tap through the holes before bolting it up to clean out the threads.
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is offline
post #9 of 9 Old 05-24-2020, 08:30 PM
80cj
80cj's Avatar
1980 CJ5
I can't remember if it applies to AMC engines but on some engines, the bolt holes are offset so they line up only one way. But I think it's obvious when you try to mount the fly wheel.
80cj is offline
