Replace resin/potting material in ICM? - JeepForum.com
 8Likes
post #1 of 16 Old 08-05-2020, 07:27 AM Thread Starter
Horatio
1980 CJ7
I've been working on cleaning up the engine bay. Found that my ICM had its potting material melted out of it and all over the inner fender. I removed the ICM and scraped up as much of the "tar" as I could. It appears to be in good condition with no visible corrosion. Has anyone ever replaced the potting material? The engine is running well so I'd like to keep this ICM. The jeep is garaged and not driven in the rain. Do I need to worry about it?
Horatio is offline
post #2 of 16 Old 08-05-2020, 07:43 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The fact that the potting material melted indicates the ICM has overheated, and it's usually a sign that it's on it last leg.
Personally, I'd bite the bullet and use this opportunity to upgrade the ignition system, before it leaves you stranded somewhere. I like the separated components of a CDI system, like MSD, but others prefer the simplicity of an HEI system. Either one will be an improvement over your original Duraspark system and should give you years of reliable service.
Just my 2 pennies and a pocket full of lint,
Matt
Cutlass327 and uptillnow like this.
Matt1981CJ7 is offline
post #3 of 16 Old 08-07-2020, 07:29 AM Thread Starter
Horatio
1980 CJ7
Matt
Matt, That's sound advice. My original intent was to keep it as close to factory as possible. I've been hesitant to pull a bunch of wire in order to install the HEI and was anticipating just replacing the ICM; however, you've got me reconsidering. This thing is certainly not going to be museum quality any time in the near future. If/When I get around to doing a full restoration, I'll likely be replacing the harness anyway, so I might as well have a reliable ignition system in the meantime.
Horatio is offline
post #4 of 16 Old 08-07-2020, 07:55 AM
weapon
1983 CJ7
If you do want to keep it stock, I think I have a couple of those lying around in the parts trader tub in my attic. I am sure lots of us who have swapped over to hei do.
weapon is offline
post #5 of 16 Old 08-07-2020, 09:06 AM Thread Starter
Horatio
1980 CJ7
Great to know. Thank you. Might not be a bad idea to source one now in anticipation of the current one crapping out.
Horatio is offline
post #6 of 16 Old 08-07-2020, 11:13 AM
only in a jeep cj
Ive had two crap out when I was many hours from home of course. Both had melted backs and one even idled fine but popped and stuttered under load/acceleration. At 12 to 20 bucks for new ones, I keep a spare in the center console. It saved an offroad trip once too.
Cutlass327 likes this.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #7 of 16 Old 08-07-2020, 10:54 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
There is a good "Stealth HEI" thread that puts a $25 HEI module inside the old case. You gut out the board and install the module and link up to the old wires. makes it plug in and out, you can swap for a Duraspark module or another HEI module on the trail.
The HEI module gets hot so needs a heat sink, that case is perfect for the job.
Unfortunately with the design of Duraspark it puts the current through the module when it is not turning over, hence heat builds up.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now
post #8 of 16 Old 08-08-2020, 06:01 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I've been working on my steering column this week and turning the key ON to move the wheel an then turning it off right way.
Finally realized I don't have to do that cause I have the wiring harness disconnected.....
Horatio likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #9 of 16 Old 08-08-2020, 06:18 AM
braindamage
braindamage's Avatar
1978 CJ5
Just buy a replacement. I went back to it after messing with MSD and it’s been fine.
Horatio likes this.
braindamage is offline
post #10 of 16 Old 08-08-2020, 07:47 AM Thread Starter
Horatio
1980 CJ7
I went ahead and pulled the trigger on a new crown ICM. Probably should have asked first, but what are your opinions on replacements vs. originals? Crown vs. OMIX?
Also, I just discovered that the OMIX headquarters is right up the road from me. They have a nice jeep collection that you can tour.
Horatio is offline
post #11 of 16 Old 08-08-2020, 08:00 AM Thread Starter
Horatio
1980 CJ7
I did some searching for the stealth HEI and keep running across this non-functional link.
This is a 'Quick Fix' you can do for about $20,
http://www.junkyardgenius.com/ignition/jeep/HEI01.html
Anyone know where I can find the actual link/thread?
Horatio is offline
post #12 of 16 Old 08-08-2020, 08:23 AM
braindamage
1978 CJ5
I think both crown and omix are junk...but it’s worked for me for a few years.
Horatio likes this.
post #13 of 16 Old 08-08-2020, 11:08 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use the Wayback Machine. https://archive.org/web/
Copy the dead link, paste into wayback, and pick a date.
Save or copy any pictures or diagrams, sometimes when they are gone, they are gone forever.
Cutlass327 and Horatio like this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #14 of 16 Old 08-08-2020, 11:23 AM Thread Starter
Horatio
1980 CJ7
Awesome! That helped. Thanks.
I attached a PDF for future reference.
File Type: pdf Junk Yard Genius.com 'Stealth HEI Page.pdf (881.8 KB, 12 views)
Horatio is offline
post #15 of 16 Old 08-08-2020, 01:13 PM
John Strenk
1976 CJ5
This is the one that JYG labeled 'Stealth" HEI
You kinda get the idea.
It was hard to find a DuraSpark module with flats inside.
