Repair of broken studs in center caps? - JeepForum.com
 1Likes
  • 1 Post By keith460
post #1 of 4 Old 06-18-2019, 12:34 PM Thread Starter
scottyDive
How in the world do you get broken studs out of the center caps. I can't use heat without damaging the chrome and drilling it out is challenging since the holes are outboard of the center and it's hard to drill straight down...anyone have a cure?
Sent from my SM-G960U using Tapatalk
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
scottyDive is offline
post #2 of 4 Old 06-20-2019, 04:32 AM
aillon
aillon's Avatar
I had to do this for my center caps too. I used a dremell to shave off the end and make it flat, then used a punch to make a little indentation. Then a drill to slowly make the holes. Its hard to keep it centered. It took a long time.
Or you can just pony up $100 for some nice ones on ebay. Not a bad deal (not my ad). I do see that a couple of these do have broken bolts now too.
https://www.ebay.com/itm/Jeep-AMC-CJ...EAAOSw9M9dBiZo
aillon is offline
post #3 of 4 Old 06-24-2019, 11:06 PM
StoneTower
Could you drill some rings out of plywood (hole saw) and layer them up to build a cradel to hold the caps up and then you would be able to use a drill press.
StoneTower is offline
post #4 of 4 Old 06-25-2019, 02:26 AM
keith460
Jeep. There's Only One
keith460's Avatar
Drill Press only for that type of work.
I had one or two like that and set it up on a piece of plywood and then used another piece of wood to hold it down with a large wood clamp. Anything else and you are going to mare the finish of the chrome. Once it was held in place and centered on Centering Drill Bit, not a regular bit, we drilled to make a small pilot hole. Then used maybe a 3/32 drill bit to a certain depth. After drilling, we used a slightly larger reversed or lefthand drill bit to remove the broken bolt. Maybe 7/64 or 1/8 reverse drill. Came right out and I had several that were broken.
Next we used a 10-24 tap to clean the threads and then installed new stainless hardware, with anti-seize compound on the threads for future removal.
The new hardware was acquired from Totallystainless.com and the are OEM type Hex Flange Bolts of 10-24 x 5/8L. There are a couple of forum threads floating around about the screws that I provided the specs on.
Sent from my iPhone using Tapatalk
scottyDive likes this.
1984 CJ-7 Renegade
keith460 is offline
