Removing bumperettes - JeepForum.com
 1Likes
  • 1 Post By Blue Bomber
post #1 of 6 Old 04-06-2021, 05:26 AM Thread Starter
Blue Bomber
Blue Bomber's Avatar
Having trouble accessing the nut on the back of this last bolt. Do I have to drop the skid plate and tank or is there a Jeep hack someone knows?
Thanks fam!
Blue Bomber is offline
post #2 of 6 Old 04-06-2021, 08:24 AM
weapon
1983 CJ7
nope. Use a long wobble extension. It is a tight fit but it works.
weapon is offline
post #3 of 6 Old 04-06-2021, 10:43 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Yes, that one is a pain. You have to blindly get a socket on it, and use a wobbly and extension as mentioned above.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #4 of 6 Old 04-06-2021, 01:32 PM
258
I need to remove my bolts and replace them with stainless steel. Ran into this issue and put replacing on the back burner till later. Nice timing on this listing showing up, lol. Does the wobble extension reach in from between tank and spring? Might as well put it on my list. HF has a Pittsburgh set of wobble extensions that are only $15; (9 piece). About to do front/rear brake shoes so I'll add those to the list of additional tools I need.
258 is offline
post #5 of 6 Old 04-07-2021, 05:50 AM Thread Starter
Blue Bomber
Perfect. Thanks fellas! I knew there had to be a work around.
post #6 of 6 Old 04-08-2021, 08:26 AM Thread Starter
Blue Bomber
Got the bumperettes off and the hitch on yesterday. The universal joint or "wobble" was the key. Thanks again!
weapon likes this.
