JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep CJ Forum (https://www.jeepforum.com/forum/f8/)
-   -   Removing bumperettes (https://www.jeepforum.com/forum/f8/removing-bumperettes-4429657/)
Blue Bomber 04-06-2021 05:26 AM
1 Attachment(s)
Having trouble accessing the nut on the back of this last bolt. Do I have to drop the skid plate and tank or is there a Jeep hack someone knows?
Thanks fam!
weapon 04-06-2021 08:24 AM
nope. Use a long wobble extension. It is a tight fit but it works.
Ken4444 04-06-2021 10:43 AM
Yes, that one is a pain. You have to blindly get a socket on it, and use a wobbly and extension as mentioned above.
258 04-06-2021 01:32 PM
I need to remove my bolts and replace them with stainless steel. Ran into this issue and put replacing on the back burner till later. Nice timing on this listing showing up, lol. Does the wobble extension reach in from between tank and spring? Might as well put it on my list. HF has a Pittsburgh set of wobble extensions that are only $15; (9 piece). About to do front/rear brake shoes so I'll add those to the list of additional tools I need.
Blue Bomber 04-07-2021 05:50 AM
Perfect. Thanks fellas! I knew there had to be a work around.
Blue Bomber 04-08-2021 08:26 AM
Got the bumperettes off and the hitch on yesterday. The universal joint or "wobble" was the key. Thanks again!
The time now is 05:58 PM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
