Reduction gear starter - JeepForum.com
 4Likes
  • 1 Post By Matt1981CJ7
  • 3 Post By JEEPFELLER
post #1 of 10 Old 06-13-2021, 09:51 PM Thread Starter
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
BagusJeep,
Got any of these?
Pros/ Cons?
I just ordered one for Willy, Sometimes Willy can be stubborn if it's been awhile since he was cranked.
Will this type starter hold up with extended cranking?
My last attempt with the OEM starter had it smoking (even when primed)
Give me the rundown on this new starter!
https://www.walmart.com/ip/NEW-GEAR-...e-f9de27af9e3c
I have good luck with warranties, I got the 3 year plan too!
----JEEPFELLER
JEEPFELLER is offline
post #2 of 10 Old 06-14-2021, 12:31 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Looks very sexy!!!!! European made by the looks of it, they are just a label but not being Chicomm is always best.
My Willys runs on a simple bendix type starter with integral solenoid, with good leads to earth and battery it spins over fine and it starts, if not instantly then quite quickly. It is related to a lawnmower after all.
I have a similar reduction starter on a 258 in Puthijeep, which came from a Mitsubishi Pajero and was cut down / welded up to fit. Maker was probably Denso so good quality. They spin real fast, the only issue being the gear drive itself which has to be kept greased. I have never measured it but I suspect it has a lower current draw than the usual one. The brushes froze on it after many years but a simple beast to repair.
A good choice.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #3 of 10 Old 06-14-2021, 06:27 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I''m running the Powermaster Mini Torque starter from Summit on my 360, mostly because it provided more room for my exhaust crossover.
It's performed well and seems to have more cranking power than the OEM style.
Matt
John Strenk likes this.
Matt1981CJ7 is offline
post #4 of 10 Old 06-14-2021, 09:43 AM Thread Starter
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Y'alls input makes me feel better about spending for one.
----JEEPFELLER
post #5 of 10 Old 06-14-2021, 11:56 AM
bob4703
1974 CJ5
Every once in a while I learn something from JEEPFELLER. It probably would be more if I could understand more if I wasn't so dense!
Today I learned you could buy a starter from Walmart and not just an ordinary starter but a reduction gear starter. Last week I learned that if you go to Walmart to buy a 3157 turn signal/stop light bulb you find them in a locked cabinet with a "Push Button for Assistance" and no one who works there knows where the light flashes when you push the button. The second thing I learned was that after waiting for 30 minutes while pushing the button was that they were out of 3157 bulbs.
That's an expensive starter. You may have to cut back on your antifreeze consumption to afford it. Let me know when it arrives.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #6 of 10 Old 06-15-2021, 11:48 AM Thread Starter
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I got him yesterday.
AIN"T HE PERTTY?!
I must now clear a path through "Hoarderville" and remove all the items I sat on and in Willy while I waited for this special moment.
----JEEPFELLER
post #7 of 10 Old 06-15-2021, 05:07 PM Thread Starter
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
See!!!!
----JEEPFELLER
post #8 of 10 Old 06-16-2021, 03:03 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Is that what they call urban camouflage!!!!
post #9 of 10 Old 06-16-2021, 06:05 AM
bob4703
1974 CJ5
When she left you the honey do list and said to clean up the garage for 30 minutes she was actually telling you the first step in putting on the starter. When you finish yours you can come do my garage. Dadgum it it is easier to just toss it in than to put it in its place. Then you can't get to that place.
bob4703 is offline
post #10 of 10 Old 06-22-2021, 08:18 PM Thread Starter
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Dug him out of the hoard.
A little EZer to get to the stuff needed to get him going.
HE's ALIVE!!!
Checked fluids--Good
Recharged battery
Primed with 2 separate squirts of starter fluid
Choke fully out
Busted off for 5 seconds with 1st squirt
Busted off full time with 2nd squirt
I minute later----choke fully off
STARTER so smooth!!!! And even, consistent
No "wing ding pop whirl etc." as the original did since 1991 (and other folks Willys with a 134)
I recommend this puppy over a OEM starter--wish I had got one in the beginning.
----JEEPFELLER
BagusJeep, bob4703 and Axhammer like this.
