rebuilt steering column - JeepForum.com
post #1 of 4 Old 02-04-2009, 05:52 PM Thread Starter
codyp8
1983 CJ7
i purchased a rebuilt tilt steering column for my old one. the new one doesnt have the inner shaft with it and i am having a hard time getting the old one to break loose. Can i salvage it or will i have to purchase a new one and if salvagable any suggestions on how to get it off
codyp8 is offline
post #2 of 4 Old 02-04-2009, 08:12 PM
Bard
Do you got a pic of what you are looking at? The steering column is held on by 2 bolts under dash, 4 on the firewall with a upper and lower flange, a coupler with a carriage bolt for the steering shaft to the box, another coupler and thats it. That can be a pain to remove, I think that is what you are referring to. Use a pry bar or just yank it all out and separate them.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 4 Old 02-04-2009, 08:24 PM Thread Starter
codyp8
1983 CJ7
naw its the shaft inside the column itself. for some reason the new steering column didn't come with the shaft that connects about halfway inside the column and runs to the end of the column
codyp8 is offline
post #4 of 4 Old 02-04-2009, 10:42 PM
479AZ
479AZ's Avatar
1978 CJ7
If you're talking about the steering shaft itself I just did mine and it wasn't too bad. The shaft has a circlip that prevents it from coming out towards the driver, it butts up against the upper bearing. Pull the column and disconnect it at the swivel joint. At the end of the column you remove the spring clip, that will allow you to remove the lower bearing carrier (plastic) and bearing, the shaft then will slide out towards the front of the vehicle. You may have to tap it with a brass hammer to get the upper bearing to let go but it shouldn't be that hard.
479AZ is offline
cj7 82 Steering column Jeeprairie82 Jeep CJ Forum 3 03-16-2013 05:12 PM
rebuilt my steering box is it easy and how. kcfire64 Jeep CJ Forum 5 03-07-2009 08:01 AM
cj 7 steering column nmcnemar Jeep CJ Forum 1 10-14-2008 09:17 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 06:16 PM
Steering column help [email protected] Jeep CJ Forum 4 02-06-2006 07:22 PM
