Rebuilding 3 tilt Columns at once. Got a bunch of questions...assistance appreciated. - Page 6 - JeepForum.com
 26Likes
post #76 of 96 Old 07-14-2020, 09:11 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by weapon View Post
i am still in the same place. All over the dinner table. Work got in the way.
Iím still trying to find the parts I took off 6 months ago...
And trying to remember how it all goes back together.
weapon likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #77 of 96 Old 07-14-2020, 11:47 PM Thread Starter
weapon
1983 CJ7
i just posted an old breakdown tutorial from Dale. https://www.jeepforum.com/forum/f8/d...-deus-4403589/
This is what I used to start my project. I have another one to cross reference.
weapon is offline
post #78 of 96 Old 07-15-2020, 04:51 AM
John Strenk
1976 CJ5
Had fun trying to press in new column bearings last night. Eventually had to remove the ball bearings and retainer and press in the race alone.
Used a socket and a drill press to press in the bearings and then pop in the ball bearings. Good thing I learned some tricks repairing bicycles.
Removing the bearings was pretty easy. There are slots in the assembly that you can put in a punch and tap them out. I'll get some pictures tonight if you want any.
I'm rebuilding a YJ column but so far it's the same a a CJ. It's going to get complicated a little further down the road.
weapon likes this.
post #79 of 96 Old 07-15-2020, 11:35 AM Thread Starter
weapon
1983 CJ7
That is the part I am not looking forward to. I have no shop press or drill press handy.
I never even thought of trying to press them in with the bearings. That is just madness. haha
weapon is offline
post #80 of 96 Old 07-15-2020, 12:01 PM
John Strenk
1976 CJ5
It was hard to tell when it was all the way down also.
My advice would be, if it's not crunchy feeling when spinning it and the race is not rusty then just replace the retainer and balls. Leave the race in place.
I'll get some pictures.
post #81 of 96 Old 07-15-2020, 09:15 PM
John Strenk
1976 CJ5
So close tonight....
Missing this screw
post #82 of 96 Old 07-16-2020, 01:48 PM Thread Starter
weapon
1983 CJ7
what is that for?
is that to lock the key cylinder in place?
mine has the tab.
weapon is offline
post #83 of 96 Old 07-16-2020, 02:30 PM
John Strenk
1976 CJ5
what is that for?
mine has the tab.
Yep,
I got a new on on order but I may see if something else can fit in there also.
I have 4 columns at home, 3 have the tab, 2 can use either tab or screw. Only this one uses the screw only.
I already tried a key cylinder with the tab and it just pulls out.
weapon likes this.
post #84 of 96 Old 07-17-2020, 07:32 PM
John Strenk
1976 CJ5
test fit on mine
post #85 of 96 Old 07-18-2020, 01:49 PM Thread Starter
weapon
1983 CJ7
test fit on mine
looks good. Wasn't it tan before?
weapon is offline
post #86 of 96 Old 07-18-2020, 02:28 PM
John Strenk
1976 CJ5
Why yes, yes it was.
But there was nothing else tan on my Jeep.
weapon likes this.
post #87 of 96 Old 07-19-2020, 06:59 PM Thread Starter
weapon
1983 CJ7
thought you did a switcharoo...
weapon is offline
post #88 of 96 Old 10-12-2020, 06:20 PM Thread Starter
weapon
1983 CJ7
Finally back at the reassembly of the columns.
Powder coated the key release tab. Cleaned and buffed all internals to a nice shine. Kinda went overboard on that but wanted to have my first rebuild as nice on the inside as on the outside. Locktite 271 on those pesky screws. Now they will stay tight until doomsday.
What terrible pain in the a$$ the bearings are. Fought that for some time. Finally got it all together after many outbursts. Buffed the Rack key.
Clean and polished the tilt spring mechanism. Greased and installed. Now the tilt snaps hard with the release. The difficult part is over. The top is very simple to reassemble.
This is going to be the cleanest oem stock tilt column ever.
weapon is offline
post #89 of 96 Old 10-15-2020, 08:20 PM Thread Starter
weapon
1983 CJ7
There were some imperfections in the lower cup that I did not like so I decided it would be best to sand and repaint before final assembly.
weapon is offline
post #90 of 96 Old 10-17-2020, 10:17 PM Thread Starter
weapon
1983 CJ7
I am looking for this part used: Tilt Steering Column Housing Cover End Cap.
weapon is offline
