Rear View Mirror Location - JeepForum.com
 2Likes
  • 1 Post By 4Low2G0
  • 1 Post By JoonHoss
post #1 of 7 Old 06-29-2020, 04:56 PM Thread Starter
DV915
DV915's Avatar
1976 CJ7
My 1976 CJ just came back from the body shop after a repaint. Iím now having a new windshield installed later this week so Iím trying to find the definitive factory location for the rear view mirror pad. My old windshield is long gone so I canít use it as a guide. I conducted a search and came across this diagram but I canít confirm itís accuracy. It shows 5 3/4 inches from the top of the frame but that seems rather low. Any thoughts or reference material?
Thanks.
DV915 is offline
post #2 of 7 Old 06-29-2020, 07:29 PM
Axhammer
Axhammer's Avatar
My 1985 CJ-7 mirror is adhered at about the same location. Mine is angled up from the mount location to put it higher where you would expect the mirror to be located. So, it seems to be correct for my CJ-7.
42237AB9-F40B-40D0-8812-E048ABE335E6_1593480434104.jpg   20E26F33-9883-479C-9C68-938C51EE9E0E_1593480488214.jpg
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is online now
post #3 of 7 Old 06-29-2020, 08:33 PM Thread Starter
DV915
DV915's Avatar
1976 CJ7
Thanks Axe, perhaps that diagram is correct!
DV915 is offline
post #4 of 7 Old 06-29-2020, 08:35 PM
4Low2G0
4Low2G0's Avatar
Keep in mind you will need the correct button for the mirror you are using, they are not all the same, there are several types.
DV915 likes this.
Whats over that next ridge?
4Low2G0 is offline
post #5 of 7 Old 06-30-2020, 06:47 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Mine are screwed to the windshield frame. The drop is only about 2". This is fine for bikini top, when I had the hard top on it was maybe a touch high.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 7 Old 06-30-2020, 03:49 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Anytime I had to replace my windshield in my Jeep (which sadly, was not un-rare), I had them mount the base higher.
Granted, I'm taller, but I always hated having it smack in the middle of my field of view, so I always had them turned like Axhammer; moving the mount meant the dimmer was back on the 'right' side.
Hoss
DV915 likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is online now
post #7 of 7 Old 07-01-2020, 07:06 AM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
I mounted mine higher on the windshield. With the top off, it is fine to see behind me. However, with the hardtop on, I have to duck my head down to see out back.
On another vehicle, I inverted the mounting bracket. This allowed me more adjustment downward to see out the back.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
