RE 4.5 Inch Extreme-Duty Leaf Spring Lift Kit Question - JeepForum.com
post #1 of 6 Old 07-18-2019, 01:50 PM Thread Starter
84jeepjedi
I just scored a great deal on this lift kit and I can't wait to install it in my 1984 CJ-7. I have a few questions for those with experience with this lift please:
Has anyone installed this lift in a Jeep with auto trans? I have the factory TF999. Does that change the drive-shaft length requirements? Will I be able to use the stock shafts or need custom?
The Jeep is currently on 31x10.5's. I am not ready yet (financially) to get the larger tires and gears I want. In the meantime, will it look silly with 31's and this lift? Anybody have pics of similar rigs?
thanks!
84jeepjedi is offline
post #2 of 6 Old 07-18-2019, 06:16 PM
Jack61
1981 CJ7
Yes you will need to get a custom length rear drive shaft with a double cardan joint for the transmission end. You most likely will need a longer front driveshaft. Yes your 31s are going to look tiny and lost.
It used to be, God bless America, it has become God help America
Jack61 is offline
post #3 of 6 Old 07-18-2019, 10:20 PM
43Duc
43Duc's Avatar
1982 CJ8
I have that lift on my CJ-8. It will lift it higher than you think and it will look a bit goofy until you get bigger tires. I have 33s on mine and I think it looks good. It's a good kit, but it will be a bit stiff - at least mine is.
1982 Jeep Scrambler w/ MBZ OM617 POWERHOUSE!!!
43Duc is offline
post #4 of 6 Old 07-19-2019, 07:19 AM
JohnnyRotten
1978 CJ5
I have that lift with 33s and mine is stiff also. It does have a 1" body lift due to shifter issues.I needed a double cardon in the rear but my front shaft was fine.
JohnnyRotten is offline
post #5 of 6 Old 07-19-2019, 10:29 AM
Megaram
Megaram's Avatar
Same here, little stiff but good quality. 33s as well
Its as real as it feels
Megaram is offline
post #6 of 6 Old 07-19-2019, 12:43 PM
BrutusBlue
1982 CJ7
They will soften up. They have proven themselves enough for me to not hesitate buying again. In the process of installing another set on a CJ8.
BrutusBlue is online now
