Radiator Fan Shroud Replacement - JeepForum.com
 4Likes
  • 1 Post By 87MJTim
  • 1 Post By Axhammer
  • 2 Post By Axhammer
post #1 of 5 Old 07-19-2021, 03:06 PM Thread Starter
c82cj
c82cj's Avatar
1982 CJ7
Sorry if this a dumb question but I have not found any clear videos on YouTube. Do I have to remove the entire radiator just to replace the shroud? Does anyone have any pics or a link to a thread on replacing the shroud?
c82cj is offline
post #2 of 5 Old 07-19-2021, 03:32 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
No, but you may have to remove the fan from the pully. I have seen people cut the lower portion of the shroud to open up to slide past the fan.
c82cj likes this.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is online now
post #3 of 5 Old 07-19-2021, 04:56 PM
Axhammer
Axhammer's Avatar
This is a pretty easy job, remove 4 nuts and four bolts.
You might want to spray the radiator bolt threads & fan stud threads with some WD-40, before starting this job.
Also, before starting make sure there is no wiring or automatic transmission lines in the way. The Dana 30 vent line is attached to the upper passenger side radiator bolt, but it is not a problem, just swing it out of the way when you have that bolt removed, and make sure you re-install it before finishing up.
Remove the 4 fan nuts, and the fan will come off of the water pump flange/pulley, I believe a 1/2” wrench is what you need here.
Use a long flat screwdriver or a small pry bar to wedge between two fan attachment nuts/studs, to prevent the fan from spinning while you break torque on the other two nuts, then do the others.
Lift the fan out carefully.
The shroud is held in place by the four bolts that secure the radiator to the front grill assembly.
Loosen all four bolts with a 9/16 socket and ratchet, leave the top bolt on each side in place, after loosening them, and remove both lower bolts, while the two upper bolts hold the radiator & shroud in place.
With the top bolts loose you can remove one upper bolt while supporting the weight of the radiator, tilt the shroud away from radiator mount flange enough to reinstall the bolt a couple threads, to support the radiator on that side.
Do the same on the other side, and then you can carefully remove the shroud.
c82cj likes this.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is online now
post #4 of 5 Old 07-19-2021, 05:21 PM
Axhammer
Axhammer's Avatar
I’ll post some pictures of mine when it was going back together when I did an engine swap.
I hope this helps.
4EA64F42-BC2E-4A86-BA7E-97208F024438.jpg   B2153E38-D920-492B-813C-5E8D142CD131.jpg   77B1169E-C271-4890-A87F-A2B31D8E86D8.jpg   C481F260-78E6-4DA1-A4DC-6B79E81F192C.jpg   B92D4C55-99F5-4655-97B9-69C5FDED4B54.jpg
c82cj and BruceinGA like this.
post #5 of 5 Old 07-20-2021, 09:34 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Axhammer is spot on.
The exact configuration of fan depends on spec but they all share 4 studs and 4 nuts.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
