Questions About my Castor Angle - JeepForum.com
 1Likes
post #1 of 19 Old 07-22-2021, 09:58 PM Thread Starter
Mayday-Joey
Hi, I have an 85' CJ-7 with a ~2.5" shackle lift. I've been trying to get it to drive more straight lol. I finally got around to checking my castor, see the pic attached. Seems to be about 6 degrees but am I measuring it in the correct location?
I put the indicator on a flat spot on the diff, I thought I had read somewhere before on this it's a good place. But if there's a better location let me know.
Other:
BTW, Before people go on an off topic rampage, I've already checked tire pressure, ball joints and tie rod ends.
I however am going to loosen the u bolts and re-torque them and the shackles. The rear axle is shifted about 1-2" to one side and the front passenger side is tilted.
my hope is I can shore up the suspension before I replace it, I don't drive it enough to replace the suspension, yet.
Second pic is just for run, not related.
85 CJ-7 4.2, a lot of unknown parts. My first Jeep!
Mayday-Joey is offline
post #2 of 19 Old 07-22-2021, 11:10 PM
jurgen24
Hard to see where you are measuring. If you draw a line through the lower/upper ball joint, that would be the caster.
Sent from my iPhone using Tapatalk
jurgen24 is offline
post #3 of 19 Old 07-23-2021, 12:44 AM
Mongo228
Junior Member
Mongo228's Avatar
1980 CJ7
I'm going through the same issue with my CJ7.
From everything I have read, you should check from the top of the upper ball joint on the knuckle.
Per the 1978 FSM, CJs came at +3* caster. Most folks go anywhere from 4-8*. I know, huge range.
Measuring from the pinion wouldn't give you the actual caster; there's some difference, usually about -2* from what I have read, baked in. It may be more or less.
There's a really good thread here about dealing with caster.
I put in the shims, but it's pouring cats and dogs here now, not to mention it's almost midnight. I'll take my beast out for a spin on Saturday to see if the 4* shims I installed helped.
Luck to you!
Dave
Mesa, AZ
"Grinders and Paint Make You The Welder You Ain't!" -- from a t-shirt
Mongo228 is offline
post #4 of 19 Old 07-23-2021, 02:05 AM
keith460
keith460's Avatar
You can't measure castor angle off the cast iron tab for the front axle bump stop. Plus, what you show is the opposite of what you need for castor angle.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 19 Old 07-23-2021, 02:28 AM
80cj
80cj's Avatar
1980 CJ5
I've seen people put a socket on the upper ball joint nut and sit the protractor on top of the socket. Probably better to take the Jeep to an alignment shop and have them measure caster, camber toe in/out.
80cj is offline
post #6 of 19 Old 07-23-2021, 07:02 AM
Renegade82
Renegade82's Avatar
1982 CJ7
Yes, thats what I found easiest. Theres not much room on the top of the "C" so putting a socket over the nut gives you a new flat spot to measure from. Your caster should be in the 5-7 degrees positive range, which means the top should be tilted back compared to the bottom.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #7 of 19 Old 07-23-2021, 10:30 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
My method is pretty EZ
If your front shackles are taller than the original shackles (even grossly taller)
You may have a caster problem!
-----JEEPFELLER
JEEPFELLER is online now
post #8 of 19 Old 07-23-2021, 10:43 PM Thread Starter
Mayday-Joey
Lol, It does have shims, but after reading how bad shackle lifts are it's still going to have issues. But I'll try measuring it off the C hub tomorrow.
Eventually the suspension will get replaced but likely not till next year.
-----JEEPFELLER
post #9 of 19 Old 07-23-2021, 10:44 PM Thread Starter
Mayday-Joey
I'll have to try it off the C hub tomorrow and see what I get.
I'll report back with what I find.
post #10 of 19 Old 07-24-2021, 12:46 AM
Renegade82
Renegade82's Avatar
1982 CJ7
That's a common misnomer. It's the poor installation that is bad. Three inch shackles isn't some magical length. Many vehicles have different lengths. Even some Jeeps used 2". Wranglers use 4". Some pickups use 5" or larger. Jeeps actually benefit using longer shackles by gaining more flex. But it has to be done right and thats where people fail and give shackles a bad rap.
post #11 of 19 Old 07-24-2021, 08:36 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Not to get off topic, but I mildly disagree with this statement. Longer shackles do more than shift caster angles, they increase lateral flex as well. This can cause steering slop. They also increase the lateral load on the front spring hangers. Not such a big issue on earlier CJ's, but on 76 and later rigs with bolt on hangers, they can flex them at the frame mounting point and eventually possibly cause loose hangers, bolt breakage, frame damage, and hanger damage. The longer the shackles, the worse the effect.
Back on topic:
I agree with 80cj. Spend the money and get a professional to run a readout and adjust the toe in. This would give you an accurate starting point for any further adjustments.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #12 of 19 Old 07-24-2021, 11:36 AM
Renegade82
Renegade82's Avatar
1982 CJ7
Back on topic:
No, we don't disagree at all. You make my exact point. Poor installation! You can't just swap shackles and be done with it. Just as in other "systems" you need to beef up all parts involved, plus shim if necessary. The mounts are notoriously weak parts and should be replaced even if no suspension change is made.
And yes, to compound that basic flaw the longer shackles do just that. They add additional lateral torque that can twist them and/or help to make that inevitable crack at the rivot hole happen sooner.
And with that additional lateral movement you need to use poly bushings, properly sized poly bushings, preferably with a steel sleeve for proper spacing for tightening of the shackle itself. System flex is the job of the bushings. Rubber is too compressible. Grease bolts are a plus for added smoothness when the suspension cycles.
And then theres the shackles themselves. Two straps of 1/4" steel and 2 or 3 bolts don't cut it. These need at a minimum 3/8" sides and a block between them to keep the sides parallel, bolted or preferably welded. You want a solid part that stays rectangular, just as the factory ones did by using a 3 sided one piece and shoulders to keep the removable side 90 degrees to the bolts. Length, I addressed that in my earlier post.
Titnado1 likes this.
post #13 of 19 Old 07-24-2021, 02:36 PM
80cj
80cj's Avatar
1980 CJ5
The factory ones aren't all that bad a design. Just wish they were a little heavier. I'm still running mine after 40 years and no problems.
80cj is offline
post #14 of 19 Old 07-24-2021, 02:44 PM
devildog80
devildog80's Avatar
1981 CJ5
Dave, had a little break in the weather here, and interested to see if you had a chance to get Klooge out for a test run, after installing the front shims? What was the result?
[QUOTE=Mongo228;41318977] I'll take my beast out for a spin on Saturday to see if the 4* shims I installed helped.
devildog80 is offline
post #15 of 19 Old 07-25-2021, 08:41 AM
Mongo228
Junior Member
Mongo228's Avatar
1980 CJ7
[quote=devildog80;41320031]Dave, had a little break in the weather here, and interested to see if you had a chance to get Klooge out for a test run, after installing the front shims? What was the result?
They helped, but didn't solve the problem. I'll drop you an email.
Dave
Mesa, AZ
Mongo228 is offline
