Quadra Trac transfer case fluid? - JeepForum.com
 3Likes
  • 1 Post By jeepdaddy2000
  • 2 Post By CSP
post #1 of 8 Old 09-19-2020, 04:48 PM Thread Starter
RyanPartridge
RyanPartridge's Avatar
1976 CJ7
Before I go placing an order online...Is there a fluid I can use that's fairly common at auto parts stores?
Thanks!
RyanPartridge is offline
post #2 of 8 Old 09-19-2020, 05:07 PM
wildbill23c
I believe the quadra-trac transfer case uses regular ATF, same that goes in the transmission....its the quadra-drive transfer case that required an additive due to the clutch packs....the quadra-trac transfer case used a viscous coupler which was self-contained and had its own fluid it wasn't lubricated by the ATF in the case, so just regular ATF.
wildbill23c is offline
post #3 of 8 Old 09-19-2020, 07:26 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
CJ's ran the original quadratrac BW 1305/1339 and it uses a cone style LS diff.
3qt 30WT non detergent oil and 8oz GM friction lube (Ford friction lube would probably work as well). Should take about 2 quarts to do the lower end and 1/2 quart for the reduction unit.
you can run ATF if you have the part time conversion.
wildbill23c likes this.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #4 of 8 Old 09-19-2020, 07:49 PM
oldschool74cj5
hello
crown now makes the fluid and quaratec has it.
https://www.quadratec.com/products/52250_99.htm
oldschool
oldschool74cj5 is offline
post #5 of 8 Old 09-19-2020, 10:30 PM Thread Starter
RyanPartridge
1976 CJ7
Thanks fellas!
post #6 of 8 Old 09-20-2020, 02:53 PM
wildbill23c
Good point, didn't think about the original "quadra-trac", I was thinking the newer versions found in the ZJ's and i think WJ's had a similar system before they went to the 247 that has clutch packs.
post #7 of 8 Old 09-21-2020, 10:48 AM
CSP
I hate to be captain obvious, but this is the CJ forum.
scooby533 and wildbill23c like this.
CSP is offline
post #8 of 8 Old 09-22-2020, 04:57 PM
wildbill23c
HAHA, no I didn't realize it was in the CJ forum. Although I didn't know the CJ's had quadra-trac I always assumed they were all part time 4WD systems....always learn new stuff. Thanks.
