Quadra trac and reduction unit fluid fill - JeepForum.com
post #1 of 3 Old 08-12-2020, 02:59 PM Thread Starter
Tbone288
1976 CJ7
hey all. I'm on the downhill leg of a 76 cj7 restoration, and ran into what may or may not be an issue. According to the service manual, when filling the transfer case and reduction unit, it states to fill the reduction unit first, "THEN" the transfer case. My issue is, when filling the reduction unit, I noticed the fluid leaking down and out the transfer case fill hole. I had taken the assembly, still connected to the th400, to a dedicated trans shop about a year ago, where they went through it all. My question is, is there a seal between the reduction unit and transfer case?? Otherwise, what would be the point of filling one before the other? Thanks for anyone's time and assistance with this. Jeff
Tbone288 is offline
post #2 of 3 Old 08-13-2020, 08:08 PM
chromegrille
1947 CJ2A
If I recall, you put a 1/2 qt.into the low range unit first.
Then 2 qts into the main Qtrac case. This makes the total 2-1/2 qts which is the correct amount for both units combined.
chromegrille is offline
post #3 of 3 Old 08-14-2020, 08:04 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If memory serves (it's been a while), the rear of the housing is enclosed with a large drain hole about half way up. This traps the fluid in the reduction unit/coupler and bearing. Overfilling the reduction unit will simply drain the excess fluid down into the main housing.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
