Quadra Trac Question; no shift lever to put it into hi or low - Page 2 - JeepForum.com
post #16 of 22 Old 07-19-2010, 09:04 PM
trw
trw's Avatar
2011 JK Wrangler
Originally Posted by Wrangler11 View Post
So you want to switch the knob when you are offroad and off road only?
correct, otherwise you may damage the Tcase or something else if you try to use E-drive on dry pavement, just the same as you would a part time case.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #17 of 22 Old 07-19-2010, 09:58 PM Thread Starter
Dudman5703
Dudman5703's Avatar
2016 JK Wrangler
Originally Posted by bigredisb View Post
Make sure you have the low range housing before you go shopping. My jeep didn't have the lever through the side of the trans hump. Upon further inspection the hole was drilled but the lever was just zip tied to the trans under the body and I had a low range housing already on it. Unless you spend a lot of time crawling off road you probably don't need 4 lo. If you decide you need 4 lo try searching craigslist locally for a whole quadratrac unit that you can remove low range from and add it to yours.
alright thanks, i'll have to do that. Its not that I offroad alot, I just like be like. Yeah, my jeep can do that! Then give all those ppl who own XJ's a run for there money... which I haven't had a problem doing that yet, but if i get beat by one i wont be able to live it down.
°llllll° Money well wasted
Dudman5703 is offline
post #18 of 22 Old 07-19-2010, 10:00 PM Thread Starter
Dudman5703
Dudman5703's Avatar
2016 JK Wrangler
I didn't know that... even when using locking hubs? like having them in 2x4?
post #19 of 22 Old 07-19-2010, 10:08 PM
jumbojeepman
1976 CJ7
Quadratrac Jeeps don't have locking hubs, unless they were installed along with a part-time transfer case kit. If you have put locking hubs on a Quadratrac Jeep that doesn't have a part time kit installed, and disengage them; then the Jeep doesn't move, the front axles just spin around.
jumbojeepman is offline
post #20 of 22 Old 07-19-2010, 10:10 PM Thread Starter
Dudman5703
Dudman5703's Avatar
2016 JK Wrangler
Yeah I have the kit, its all installed. I remember because I didnt initially know it was AWD and i switched the hubs to 2x4 and it wouldn't move! xD
But yeah, with that installed it it bad to switch it over for a 2x4 operation?
post #21 of 22 Old 07-20-2010, 12:14 PM
jumbojeepman
1976 CJ7
I'm confused, are you saying that you initially put a set of locking hubs on, realized they were totally worthless, then got a part-time kit for you Quadratrac t-case? Or you installed hubs and didn't install a part-time kit, and your Jeep now won't move with the hubs disengaged?
If you in fact installed the part-time kit, you need to run in 2wd mode on the street, as you front and rear driveshafts are locked together. The binding from driving this on the street will lead to parts breakage.
If you didn't, you need to leave your hubs locked in all the time, better yet sell them and get some drive plates.
post #22 of 22 Old 08-09-2018, 02:20 PM
PapaMarkC
Originally Posted by KMD View Post
I have a lever in my 76 I could take out for you. I have a dana 20 in mine now.
Just came across this thread. It's been many years, so apologies, but if you still have the origional low gear transfer case shift mechanism, I need one. I have a 1976 CJ7 with quadratrac which has the gear reduction unit, but the shift mechanism is missing. It can be engaged with a crescent wrench, but if I can get it working from the cab that'd be awesome. I plan to need it as I will be rock crawling.
PapaMarkC is offline
high range , low range , quadratrac , quadratrac switch , shifter
correct way to shift in to 4l with quadra trac? Wrangler11 Jeep CJ Forum 6 04-25-2010 09:19 PM
Quadra trac Lever Location jdfullgraf Jeep CJ Forum 2 10-15-2008 05:41 AM
Quadra trac question tyler_stephen Jeep CJ Forum 4 12-15-2007 09:12 PM
Quadra-Trac Question Crash'emup Jeep CJ Forum 2 09-28-2007 07:35 PM
1978 quadra-trac question 1978jeepcj7 Jeep CJ Forum 3 05-17-2006 08:42 PM
