Project CJ7Years - Page 2 - JeepForum.com
 23Likes
post #16 of 67 Old 12-12-2020, 01:49 PM
IronBender
1982 CJ8
Did you do the oil pump pickup tube mod while you had the pan off?
IronBender is offline
post #17 of 67 Old 12-12-2020, 02:42 PM Thread Starter
houstoniancj
houstoniancj's Avatar
I swapped over to the Fbody pickup tube, but don’t remember modding it. I did the tube girdle/brace while I was in there. I also spent the time to get the correct color o ring on the tube. What a racket...
Can you share more about the mod?
1985 Jeep CJ7
houstoniancj is offline
post #18 of 67 Old 12-12-2020, 10:59 PM
IronBender
1982 CJ8
post #19 of 67 Old 12-13-2020, 07:14 AM
Axhammer
Axhammer's Avatar
I like this CJ-7 build. I am planning one a little less extreme, using a 9” in the rear (58” WMS width) and Hi pinion 44 in the front (59”-60” WMS width). Can you clarify what the lift & tire size is in the picture from post #1 (below)
I believe it is from when you first bought it, when it was SOA on YJ springs & 35’s. Do you recall the WMS width dimension in this picture?
Did you move the front axle forward when you did the shackle reversal? I’m curious if you stretched the wheel base.
I look forward to this CJ-7 coming together and thanks for sharing.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #20 of 67 Old 12-13-2020, 07:59 AM Thread Starter
houstoniancj
It was SOA with YJ springs on 35’s in that photo. The YJ springs were nice but they were flat in this photo so really no lift from them. I want to say 61” WMS. I don’t recall the exact measurement. That picture the front was a Scout 44.
The Jeep wb now has been stretched 3” no nothing extreme. Most of that was moving the front axle forward.
1985 Jeep CJ7
post #21 of 67 Old 12-13-2020, 09:42 AM
ddawg16
ddawg16's Avatar
This is my CJ with SOA on stock Wrangler springs...first pic, 33's. Second pic, 35's
ddawg16 is offline
post #22 of 67 Old 12-14-2020, 10:00 AM
Axhammer
Axhammer's Avatar
That red sure does change colors when you get it in the sun. Thanks for posting. I’ll probably send you a PM when I get closer to ordering my springs for my SOA YJ leaf spring conversion. I hate to muck up the OP’s build thread any more, hopefully he doesn’t mind.
Axhammer is offline
post #23 of 67 Old 12-14-2020, 10:18 AM Thread Starter
houstoniancj
Fine by me. I also forgot to mention that with the original picture of the CJ it also had a 1" body lift.
Here are some more pictures from the sides.
post #24 of 67 Old 12-14-2020, 08:29 PM
ddawg16
ddawg16's Avatar
Top pic was maybe 1 month after painting.
Bottom pic....about 8 years later.
Jeep is due for a new paint job. I have some cancer on her...in a tough spot to fix. And I'm about to put some flat fenders on her....I might just get a new tub and and build it up the way I want.
ddawg16 is offline
post #25 of 67 Old 12-28-2020, 08:36 PM Thread Starter
houstoniancj
Finally got the time to get some work done after Christmas. I hope everyone had a good one. I had to get the transmission and transfer case crossmember done so I can finish fuel lines and get the body on. TDK with their nv4500 skid plate is perfect for an LS swap with a GM auto transmission. It flattened out my belly as much as possible and covers most of the transmission Pan and atlas case. It’s very adjustable in terms of the mount so I played around with it to get it perfect for my Jeep. I then started fuel line routing, I have a return less rail LS so I’m using a corvette regulator and filter in one with the AN6 fittings braised on. This made my life super easy for the hook ups for the EFI fuel line. I found an eBay seller that makes these spin on fuel filter mounts and I thought that would be great for a pre filter before my regulator. The pressure regulator is a 5 micron, and the Napa filter is a 10 micron with a very high flow rate. This way it shouldn’t starve the upstream components and be a great option to keep the regulator/filter from speedway clean longer? At least that’s my thoughts. Emergency brake cables from are next.
post #26 of 67 Old 01-14-2021, 06:57 AM Thread Starter
houstoniancj
Had some time to hash out the rest of the fuel system, and start working on some electrical connections. I have been researching out priming the oil system since I replaced the oil pan and pump during the build up of the LQ4. I looked at the melling and moroso pressure oiler but couldn't make myself spend over $100 for a single use tool.
I read from forums and came up with the same idea others have used, a pressurized garden sprayer and tome -AN barb to ultimately end up at Metric for the front oil galley. Parts below:
-4 AN Female with barbed end
-4 male to -6 AN female reducer
-6 AN Male to M10-1.5
-Amazon garden sprayer (whatever was cheapest)
Put 2 quarts in and pumped it up after hooking up an oil pressure gauge, and surprisingly it got me to 10psi. I did 2 quarts this way, rotated the engine by hand, and did another 2 quarts. The rest went into the oil filler.
This worked perfectly, and i was into it maybe $30. After priming the fuel system by filling the tank with 2 gallons, then powering the pump with the fuel line disconnected from the engine and pointing back into the fuel can I was ready.
I hooked all lines up, pressure tested for leaks, and hooked the battery up.
Man it felt good to hear an engine run after starting this project almost 7 years ago.
post #27 of 67 Old 01-14-2021, 07:02 AM Thread Starter
houstoniancj
First start video, i wasn't expecting it to fire off so quickly.
John Strenk, JoonHoss and Axhammer like this.
post #28 of 67 Old 01-14-2021, 08:35 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Thats got to be a nice feeling!
Hoss
houstoniancj likes this.
I used to be a people person, until people ruined it...
JoonHoss is offline
post #29 of 67 Old 01-14-2021, 08:41 AM Thread Starter
houstoniancj
100% it is, nothing provides more motivation than the small victories.
post #30 of 67 Old 01-18-2021, 04:42 AM
ddawg16
ddawg16's Avatar
In the old days, we pulled the handle off a long SO screwdriver, attached it to a drill, pull the dist and shove the drill down on the oil pump shaft
ddawg16 is offline
