Picture needed - JeepForum.com
 7Likes
post #1 of 20 Old 09-18-2021, 03:04 PM Thread Starter
JERSEYJOE
JERSEYJOE's Avatar
Picture needed
i NEED A PICTURE OF A CJ TUB LEFT SIDE WHERE THE CLUTCH ROD POKES THROUGH THE FIREWALL. I AM PUTTING A WRANGLER TUB ON AND THEY HAD HYDRAULIC CLUTCHES SO NO PROVISION FOR A MANUAL CLUTCH ROD. I JUST WANT TO MAKE SURE I POKE THE HOLE THROUGH IN THE RIGHT SPOT.
SPEED COSTS MONEY: HOW FAST DO YOU WANT TO GO?
JERSEYJOE is offline
post #2 of 20 Old 09-18-2021, 03:10 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
AND YOU HAVE DECIDED NOT TO CONVERT TO A HYDRAULIC CLUTCH? WHY ARE WE YELLING AT EACH OTHER?
I have a 1978 and an Ď80 tub. I can measure but I donít know 100% that it is the same any your Ď85.
uptillnow likes this.
OrangeCJ-5 is offline
post #3 of 20 Old 09-18-2021, 03:17 PM Thread Starter
JERSEYJOE
JERSEYJOE's Avatar
Not yelling
Sorry I have very poor eye sight and capitals make it easier for me to read. Sorry. I have everything set up for the stock clutch and would rather not run a hydraulic unless you talk me into it! LOL
JEEPFELLER likes this.
post #4 of 20 Old 09-18-2021, 04:37 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
I’m pretty sure an ‘85 have been hydraulic from the factory? Did you change something?
post #5 of 20 Old 09-18-2021, 04:55 PM Thread Starter
JERSEYJOE
JERSEYJOE's Avatar
clutch
I may have listed the wrong year. T he one I took apart was possibly not an 85. There is mechanical linkage and I have already prepped to use it. Not really interested in the Hydraulic set up.
post #6 of 20 Old 09-18-2021, 05:43 PM
keith460
keith460's Avatar
Here's a picture of the location from measurements I took off of my 84' tub to be transferred to the Replica-Tub I replaced it with years ago.
Establish the 10-5/8" center line first and foremost from the outside edge of the tub. You must make the hole 1-5/16"W x 1-5/8"L as the opening is elongated for the clutch rod clearance.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 20 Old 09-18-2021, 06:45 PM
Rtracy2001
Originally Posted by OrangeCJ-5 View Post
Iím pretty sure an Ď85 have been hydraulic from the factory? Did you change something?
My 4 cylinder model was hydraulic from the factory, my Brother-in-law's 86 with the 258 was linkage from the factory.
Looks like you got the info you need to pole the hole in the firewall.
Every 20 minute job is just one broken bolt away from a three day ordeal.
Rtracy2001 is offline
post #8 of 20 Old 09-18-2021, 07:06 PM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
You didn’t list any year for anything. I was going by the 1985 in your profile.
My ‘78 had mechanical linkage and the donor ‘80 tub was hydraulic. I figured everything had gone hydraulic by the mid 80’s.
post #9 of 20 Old 09-18-2021, 07:13 PM Thread Starter
JERSEYJOE
JERSEYJOE's Avatar
Thank you
THANK YOU!
sincerely appreciate the above and beyond information you provided.
Please PM to me your email address.
Again many thanks!
post #10 of 20 Old 09-18-2021, 07:17 PM
Jim1611
Jim1611's Avatar
My 85 had a mechanical clutch mechanism.
STJP likes this.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #11 of 20 Old 09-18-2021, 07:54 PM
RiverandSand
1980 CJ5
I believe only 4 bangers had the hydraulic clutch. My 80 was a 4 cyl and had the hydraulic setup which was transferred to my current setup.
RiverandSand is offline
post #12 of 20 Old 09-19-2021, 03:25 AM
keith460
keith460's Avatar
That's true, only the 4 cylinder equipped CJ's had the hydraulic clutch from the factory, all others were mechanically linked as far as I know.
My wife's 84' came equipped with the 4 cylinder engine and hydraulic clutch.
1984 CJ-7 Renegade
keith460 is offline
post #13 of 20 Old 09-19-2021, 04:29 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I'd much rather have the mechanical!
-----JEEPFELLER
JEEPFELLER is offline
post #14 of 20 Old 09-19-2021, 06:17 PM
Rtracy2001
-----JEEPFELLER
Agree to disagree. I have had both and IMO, a properly functioning hydraulic clutch beats a properly adjusted linkage clutch any day. Admittedly, getting the "properly adjusted" aspect can be a bit challenging when building or retrofitting a hydraulic system from scratch, but for me it is more than a fair trade for not having to worry about pivot point wear, plastic bushings, pivot point brackets pulling out of the bellhousing, bent pushrods, lost pushrods, etc.
schardein likes this.
post #15 of 20 Old 09-19-2021, 07:27 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
See this Rtracy2001
Post 5 - 10 in this link https://www.jeepforum.com/forum/f8/o...bolts-4397129/
Everybody else says the Heim stuff is just as good-----They were not around over 10 years ago when I made mine EZ and bullet proof with longevity.
-----JEEPFELLER
