PCV Valve Grommet - JeepForum.com
post #1 of 5 Old 06-13-2021, 06:12 PM Thread Starter
JeepGuy41
JeepGuy41's Avatar
Cj PCV Valve Grommet
Hi, I am getting oil leaking out of around my pcv valve grommet on the aluminum valve cover. It is on an 84 CJ7 with the 4.2L. I have looked everywhere and have yet to find a new grommet that fits. The current one is an omix grommet that seems cheaply made due to it not sealing well. Any suggestions or recommendations of where I can find these grommets will be appreciated.
JeepGuy41 is offline
post #2 of 5 Old 06-13-2021, 07:10 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Local parts stores?
Seems that "O'Reilly Auto Parts" and Pep boys had a good selection
I grab extras sometimes.
-----JEEPFELLER
JEEPFELLER is offline
post #3 of 5 Old 06-13-2021, 07:47 PM
fibersport
Just out of curiosity, do you have two holes in your valve cover - one up front and the other at the back? If so, is the rear one open and allowing air into the engine? If not, then you are pressurizing the engine. If you don't allow air in, you will get oil out.
1984 CJ7 Renegade
4.2 with 4 speed
researching other details!
fibersport is offline
post #4 of 5 Old 06-14-2021, 08:22 AM Thread Starter
JeepGuy41
JeepGuy41's Avatar
Yes I do have two holes on the valve cover. The rear hole connects to the air intake.
post #5 of 5 Old 06-14-2021, 02:08 PM
fibersport
OK, just checking. The previous owner of mine had PCV valves installed in both openings which pushed oil out of the dipstick.
1984 CJ7 Renegade
4.2 with 4 speed
