Oil pressure gauge - JeepForum.com
 1Likes
  • 1 Post By John Strenk
post #1 of 6 Old 09-10-2021, 07:21 AM Thread Starter
MainCJ7
1976 CJ7
Oil pressure gauge
I am replacing the amp meter, previous owner installed, with a voltmeter. While I am at it I am replacing the oil pressure to have both gauges look original. Found out the oil pressure gauge is a mechanical gauge. While not original looking, I was of the opinion that mechanical oil pressure gauges were more accurate and reliable. Opinions on matching gauges or leave the oil pressure gauge as is?
MainCJ7 is offline
post #2 of 6 Old 09-10-2021, 08:51 AM
RiverandSand
1980 CJ5
I did the same thing, replaced the broken original with Autometer classic 2". I used mechanical oil and a matching volt gauge. I have used mechanical oil gauges where I can, they are usually more sensitive to pressure changes than electric.
RiverandSand is offline
post #3 of 6 Old 09-11-2021, 04:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Just make sure to use a metal line with a mechanical gauge.
OrangeCJ-5 likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 6 Old 09-11-2021, 01:04 PM Thread Starter
MainCJ7
1976 CJ7
Mechanical gauge already installed, just wondering if it made sense to change back to electric to match voltmeter…
MainCJ7 is offline
post #5 of 6 Old 09-12-2021, 08:51 AM
bob4703
1974 CJ5
I considered this when I changed to a mechanical gauge. When you consider the cost of the gauges which are close to the same and then the sending unit you'll find it is as much if not more than the cost of the gauge.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #6 of 6 Old 09-12-2021, 09:19 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Mechanical gauges are more reliable and accurate.
Aesthetics or reliability? Your answer to that will answer your original question.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
