Oil dipstick and tube - JeepForum.com
 2Likes
  • 2 Post By JEEPFELLER
post #1 of 3 Old 10-24-2021, 11:05 AM Thread Starter
kmiller7351
1981 CJ7
The one i ordered doesnt fit or needs modification. Any help is great. Mechanic i asked to install said a piece is broke off inside hole and i need to drop oil pan ect.
kmiller7351 is offline
post #2 of 3 Old 10-24-2021, 06:35 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Using a rod that is close, but free moving in the hole. Grind it a little as shown, you might hacksaw your "line" to avoid a rounded edge, then grind it.
If you can keep the grabber pulled up tight while you "Hammer"---it might not dent/ disfigure the inner end, so it can be pulled on thru
If you can get enough to grab to come out----stop with this tool!
Then find a rod or drill bit that will fit almost snug (DON'T LET IT FALL IN) run some tape around it to keep it topside.
This will keep it from squishing/ slipping loose when you grab it perpendicular with some vice-grip plier and tap on the vise-grips to finish your extraction.
Depending on how tight it is and how much is inside will let my "Whizzy Tool" effectively work.
Otherwise---go find you a pan gasket!
Note---Reinstall the new one???? Stick it in the freezer for a long while to shrink/ contract it.
-----JEEPFELLER
sonnychiss and kmiller7351 like this.
JEEPFELLER is offline
post #3 of 3 Old 10-25-2021, 07:30 AM
Kickstart
Junior Member
Kickstart's Avatar
1983 CJ5
You might want to try a blind hole puller.
Kickstart is offline
