oem Storage box hinge question - JeepForum.com
 14Likes
post #1 of 35 Old 08-21-2019, 01:14 PM Thread Starter
xlrate66
xlrate66's Avatar
Has anyone ever replaced the hinge on one of the old CJ7 oem storage boxes?
Ive read some of the old threads talking about home depot as a source but no luck nowadays
Thanks
Rick (new member)
xlrate66 is offline
post #2 of 35 Old 08-21-2019, 01:19 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It's called a piano hinge, and Grainger has them in different lengths.
https://www.grainger.com/product/4PB...SABEgIHOvD_BwE
Matt
chatham likes this.
Matt1981CJ7 is offline
post #3 of 35 Old 08-21-2019, 01:44 PM
pedal2themetai
1956 CJ5
you can also go to your local hardware store and get them..
pedal2themetai is offline
post #4 of 35 Old 08-21-2019, 02:26 PM Thread Starter
xlrate66
xlrate66's Avatar
I actually found the exact length on Amz but wasn't sure about removing the rivets without damaging the box.? YOu may see it up for sale here soon haha
xlrate66 is offline
post #5 of 35 Old 08-21-2019, 02:27 PM Thread Starter
xlrate66
xlrate66's Avatar
Thx, tried that initially but none even close
xlrate66 is offline
post #6 of 35 Old 08-21-2019, 02:32 PM
Hoover7
Hoover7's Avatar
If you are considering selling it, I'd be interested, as I'm sure others would be as well!
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #7 of 35 Old 08-21-2019, 03:20 PM Thread Starter
xlrate66
xlrate66's Avatar
For sure I will (and at a reasonable price)
Hoover7 likes this.
xlrate66 is offline
post #8 of 35 Old 08-21-2019, 03:51 PM
StoneTower
Getting the rivets out should not be a problem. To make it look right, you want an aluminum hinge that YOU drill the holes in. To get the rivets out, start small and keep working up a size with a full set of NUMBER, Letter and Fraction bits. You want to be sure you have the right size choices and not drill too big or you will drill into the plastic where the new rivets need to grip. You don't want to spin the rivet which could melt the plastic. With a full set of bits to choose from, you can probably drill it out with three different drill sizes. If I was doing it, I would cool the rivet while drilling with a spray bottle full of water so the plastic does not melt. The rivets look to be aluminum. I would save the old hinge and use it as a template to drill the new aluminum hinge. If you look around and find the same sized aluminum pop rivets, and the proper aluminum hinge, you will have a 100% restoration of the hinge part of the box. You should be able to get the little ends of the rivets that fall off out of the hole that is in the front of the box. You can leave them in if you don't mind the extra pieces rattling around in there. There are lots of people around who would like one of those boxes. Good Luck.
trailhead2004 likes this.
StoneTower is offline
post #9 of 35 Old 08-21-2019, 04:01 PM
whollsee
1982 CJ7
If you are going to sell it why not as is with the oem hinge and the new owner can deal with it how they wish? It will still sell.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is online now
post #10 of 35 Old 08-21-2019, 05:10 PM
trailhead2004
trailhead2004's Avatar
1980 CJ7
As Stonetower mentioned, you want to drill the holes in the hinge so that the spacing is correct. It wouldn’t surprise me if they’re on a common number like 4 inches center to center. But if they were drilled on installation they could be a little off.
McMaster Carr is also a good spot to look for the hinge you need.
I have never seen one of these storage boxes, would it be possible that there’s a steel backer or washers behind the plastic to back up the rivets? I know they’re pop rivets but I wouldn’t expect a lot of gripping power with just the plastic.
trailhead2004 is online now
post #11 of 35 Old 08-21-2019, 05:27 PM
whollsee
1982 CJ7
Yep spot on. Alum washers. Hinge is alum... just took pic...
post #12 of 35 Old 08-21-2019, 05:41 PM
StoneTower
These are all undrilled aluminum hinges.
https://www.grainger.com/category/ha...&filters=attrs
post #13 of 35 Old 08-22-2019, 08:01 PM
jakesdad
Newbie
jakesdad's Avatar
I bought a stainless piano hinge for mine from Amazon. It was under $20, free shipping, and it worked well. Still don't know how Amazon made money on that deal. The box, shipping and handling costs had to be $20+.
Stainless Steel 304 Continuous Hinge with Hole, Bright Annealed Finish, 0.04" Leaf Thickness, 1-1/4" Open Width, 5/64" Pin Diameter, 1/2" Knuckle Length, 4' Long (Pack of 1)
Spieg8 likes this.
jakesdad is offline
post #14 of 35 Old 08-23-2019, 10:45 AM Thread Starter
xlrate66
xlrate66's Avatar
Wow, really excellent information. I've ordered a similar hinge yesterday so will see how it works. Did you have to drill new holes or did the new hinge line up properly?
xlrate66 is offline
post #15 of 35 Old 08-23-2019, 10:47 AM Thread Starter
xlrate66
xlrate66's Avatar
Great info and suggestions! Thanks. Will update once the hinge arrives!
xlrate66 is offline
