OEM steering gear to PSC - JeepForum.com
 1Likes
  • 1 Post By RARECJ8
post #1 of 11 Old 01-19-2020, 07:55 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
it Begins. Old gear was not leaking but tired, in hard use since 81. Amazed she lasted this long...
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is online now
post #2 of 11 Old 01-19-2020, 07:56 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Replaced intermediate steering shaft bearing.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
post #3 of 11 Old 01-19-2020, 07:58 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Getting more mount and box mocked into place. Heavy frame repair as well.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
post #4 of 11 Old 01-19-2020, 08:01 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Old steering cross frame brace. Beefy but awaits a major do over, stay tuned. Need better capture on box. We have seen the more brace fail after hard use.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
post #5 of 11 Old 01-19-2020, 08:03 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Brace to box capture detail.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
post #6 of 11 Old 01-19-2020, 08:15 PM
Fourtrail
1974 CJ6
Not tapped for hydro assist?
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #7 of 11 Old 01-19-2020, 08:20 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
It is indeed. Red circle...
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
post #8 of 11 Old 01-19-2020, 10:00 PM
lovett86
lovett86's Avatar
When I did the lower column bearing on mine (yj) it was non existant. Just an old bearing race seized on the shaft.
its a rusty one
https://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #9 of 11 Old 01-20-2020, 08:51 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I have seen a SBC connecting rod used to make a clamp for around the steering box. Find one with the right inner diameter, cut that "C" off of that one, weld the con rod on.
Rick
Cutlass327 is offline
post #10 of 11 Old 01-20-2020, 09:30 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
We are on that, lol. 2.21” ID. SBC it is! Pic for attention. But we will not use old wrenches as twin stick levers. 👀
Cutlass327 likes this.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
post #11 of 11 Old 01-20-2020, 09:37 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
The old brace capture was open horseshoe design. Uses set screws. New connecting rod idea will fully encapsule the housing. Then graft onto the cross brace.excited to do it. But look how the old set screws dug into the gear box housing. Should be riding lower on the collar but wow. That’s a lot of force.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
