OEM Clock Restoration and Install - Page 2 - JeepForum.com
 95Likes
post #16 of 375 Old 10-10-2017, 09:20 AM
Hoover7
Hoover7's Avatar
Thanks, Matt. I'm going to find mine this evening and see if I'm seeing the same thing you are. I purchased an OEM set (tach also), and after reading Keith's comment, I'm hoping the clock is the quartz version. I recall some slight discoloration near the clock adjustment knob that I'll need to address providing the clock actually functions.
Hoover
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #17 of 375 Old 10-10-2017, 10:30 AM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hey Keith,
Or anyone who has torn apart one of these clocks.
Does the adjustment knob have to come off, first, before the bezel and lens can be removed? if so, how does the knob come off?
Thanks
Matt1981CJ7 is offline
post #18 of 375 Old 10-10-2017, 11:43 AM
wm69
Here's a thread I had bookmarked. Might be worth sending it off.
http://www.cj-8.com/forum/showthread...y-Clock-Repair
wm69 is offline
post #19 of 375 Old 10-10-2017, 12:44 PM Thread Starter
Matt1981CJ7
1981 CJ7
Well, gentlemen, I'm still looking for a OEM clock for my Ol' Girl, damnit.
Once i figured out the adjustment knob just pulls off, I sharpened the tip of a paint can opener, and got busy with the tedious chore of lifting the crimp on the back of the bezel.
You have to get the crimp nearly vertical before the bezel will separate from the housing. Once is does, the bezel, inside trim plate, lens, paper gasket, rubber o-ring, and the housing will all separate.
post #20 of 375 Old 10-10-2017, 12:48 PM
keith460
keith460's Avatar
Originally Posted by Matt1981CJ7 View Post
Once i figured out the adjustment knob just pulls off...
It doesn't pull off, you have to unscrew it as the end of the adjustment rod is threaded with something like 4-40 threads.
1984 CJ-7 Renegade
keith460 is offline
post #21 of 375 Old 10-10-2017, 12:48 PM Thread Starter
Matt1981CJ7
1981 CJ7
To remove the guts from the housing, you need to straighten 3 tabs that protrude thru the housing.
post #22 of 375 Old 10-10-2017, 12:57 PM Thread Starter
Matt1981CJ7
1981 CJ7
Unfortunately, that's where this How-To ends.
The inner mechanism is built on a plastic frame, like the frame of a 3-story building. The upper floor of the frame holds the spade connectors and their rubber boot.
Apparently, whoever removed this clock got too aggressive while pulling on the wires, and broke that upper floor. It crumbled out in pieces. Then, as I was trying to free the gears, so that the hands would move, one of the tiny gears broke away from the frame. That's when the whole mess got tossed into the trash. Bummer.
post #23 of 375 Old 10-10-2017, 01:01 PM Thread Starter
Matt1981CJ7
1981 CJ7
OK, I see that now, thanks for clarifying. I guess my old eyes are too far gone to be a clock builder.
Matt
post #24 of 375 Old 10-10-2017, 01:06 PM
Hoover7
Hoover7's Avatar
What a complete drag, Matt. I'm disappointed for you. However, don't toss it in the trash just yet! You've inspired me to get mine out and start the same process. Given my clumsiness, I'll likely break something and have need of a replacement part. Who knows, you might be able to recoup a few bucks from me, or others, as they go through the process-
Hoover
Hoover7 is offline
post #25 of 375 Old 10-10-2017, 01:14 PM Thread Starter
Matt1981CJ7
1981 CJ7
Hoover,
OK, I'll save everything for now. Just PM me your address, and I'll send you everything, if you need it.
Matt
post #26 of 375 Old 10-10-2017, 03:25 PM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Matt
I have a clock from a 78 and the shaft was splined, no threads. So you would just pull it off. But just like yours all the plastic was in pieces. Fortunately mine came with the tach you have for basically nothing, a throw in.
Sorry to hear about yours
Ernie
"Beer is proof that God loves us and wants us to be happy" - Benjamin Franklin
Every Loaf of bread is the tragic story of grains that could've become beer but didn't.
Guy Smilie is online now
post #27 of 375 Old 10-10-2017, 03:56 PM Thread Starter
Matt1981CJ7
1981 CJ7
Ernie,
Thanks. You are correct, the adjustment rod is splined not threaded. I had to break out the magnifying glass to see it. It's rare for Keith to be mistaken.
BTW, the tach I got from you continues to work perfectly. Thank you very much!!
Matt
post #28 of 375 Old 10-10-2017, 04:57 PM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Glad to hear that!
Ernie
post #29 of 375 Old 10-10-2017, 05:16 PM
scottyDive
Before you do....call isi and talk to a tech. They had the replacement quartz movement, the adjusting knobs and the lenses...not cheap but mine looks brand new and is accurate to the second. https://www.clocksandgauges.com/
I bought the quartz movement off their ebay store for about 80 bucks and polished my lens and used fluorescent orange model enamel paint for the hands. I also used a led bulb from superbrightleds
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
scottyDive is offline
post #30 of 375 Old 10-10-2017, 05:27 PM Thread Starter
Matt1981CJ7
1981 CJ7
Scotty,
If you don't mind my asking, what did they charge you to rebuild your clock?
Matt
