JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep CJ Forum (https://www.jeepforum.com/forum/f8/)
-   -   OEM Clock Restoration and Install (https://www.jeepforum.com/forum/f8/oem-clock-restoration-install-4176346/)
Matt1981CJ7 10-09-2017 07:45 PM
Hey guys,
I've been looking for a factory Quartz clock for a while, and finally pulled the trigger on one I found on eBay. I hope to document the restoration and install of it here.
It arrived today and appears in decent shape. No rust on the bezel or the housing. The lens isn't horribly scratched, but could use some polishing (suggestions on that are welcomed). The hands are a bit faded, but tolerable.
I have some concerns, however. First, I assume the button at 6 o'clock on the face is suppose to be used to the set the time, correct? When I pull the button out and try to turn it, it doesn't turn and the clock hands don't move. I'm pretty sure that's not correct. Can anyone confirm?
Second, it came with no wires. It does have 2 spade connectors on the back. Does anyone know where I can buy the connections necessary to plug into the factory harness behind the dash?
Finally, the light bulb and bulb receptacle is MIA. Any suggestions on a suitable replacement? Honestly, if I had noticed this one beforehand, I probably wouldn't have bought it.
Anyway, I hope this doesn't turn into $90 mistake, but I guess that's the gamble you take when purchasing used items on eBay.
Thanks in advance for any suggestions and/or information.
Matt
John Strenk 10-10-2017 04:56 AM
Yes, It should be able to set the time that way.
That does not bode well.
keith460 10-10-2017 05:26 AM
Matt, I hope the clock you purchased is at least the Quartz version as they seem to be less problematic than the older version. And the quartz clock is very accurate.
The knob at the 6 o'clock position is for setting the time as John mentioned. The cover, if only scratched, will be hard to get back clear again. I tried several ways to clear my original yellowed cover with polishing compound for plastic, headlamp polish and good old tooth paste and still could not get it clear. The clock covers are made of ABS plastic and harmful UV rays from the sun yellowed it over time. Had to replace mine with a polycarbonate cover I made. shortcut here: https://www.jeepforum.com/forum/f8/cj...l#post10794261
Wiring for the clock was plug-n-play. A ground wire gets attached and the clock came with a fuse panel tap plug that pops into fuse panel on the 'clock' terminal. Somewhere on the the WWW, you can get fuse panel tap plugs but I found one at the junk yard off a Chevy for my radio when I broke the original one off.
Matt1981CJ7 10-10-2017 06:36 AM
Thanks guys,
Keith, yeah it's Quartz. I'd say this lens is more yellowed than scratched, too, so I'll replace it as you did, if I get the darn thing working.
For some reason I thought there was a dedicated factory harness for the clock, like the tach. Thanks for clarifying that it plugs directly to the fuse box.
John, the frozen adjustment knob and hands has me the most concerned. I'm hoping some lubrication might free things up, but I'm not optimistic. Oh well, nothing ventured nothing gained. I'll tear in to, today, and report what I figure out.
How about the light bulb and receptacle? It appears to mount in a 1/2" hole on the back of the housing. Any ideas where/what I could use there?
Matt
Jim1611 10-10-2017 07:03 AM
Matt when I bought my Centec wiring harness it came with all new bulbs, such as what the gauges use. They may have a bulb for your clock as well. http://www.centechwire.com/Jeep-CJ-W...Harness-JP.htm
cj401 10-10-2017 07:12 AM
If the clock was misrepresented in the Ebay listing, I'd contact the seller. If it's returnable, I would do so.
Guy Smilie 10-10-2017 07:35 AM
Matt, I needed a socket for the bulb on the back of a OEM tach I purchased and got one from J&W in Ca. jwjeep.com, they may have what you need.
rrekr 10-10-2017 07:41 AM
Should be able to use 1/4" female spade terminals for the power and ground. The case is grounded thru the ground wire for the power ground wire(internally) and will let you use the same single wire light holder as the other gauges such as volt or oil pressure gauge. The owners manual says to use an 1892 bulb. Mine looks like a peehole in a snowbank with that setup. I've put led bulbs in it with little improvement. Be interesting to see what you come up with.
Matt1981CJ7 10-10-2017 08:05 AM
All great suggestions and info, guys. Thanks!!
The seller really didn't misrepresent this clock. His only description was "appears in decent shape", but he didn't claim it actually worked.
I'll either fix it, or break it for good. Man, there are some tiny parts in this thing!!
Matt
Hoover7 10-10-2017 08:24 AM
Matt, when you have a moment, please post a few pictures! I also have an OEM clock and will be following your lead on this-
Hoover
John Strenk 10-10-2017 08:27 AM
If it was me and your not leaning to keeping it all original, I'd look for a High output LED and wire some wires it and hold it in place with a foam or rubber plug.
Need to figure out which LED though as they are very directional.
Are you going to take it apart?
http://i234.photobucket.com/albums/e...2/DSCF0110.jpg
Matt1981CJ7 10-10-2017 08:34 AM
Hoover,
Will do. I have some errands to run this morning, but I hope to get back to it this afternoon.
I'm really not to sure what I can do to free the mechanism up on this thing, besides compressed air and maybe some light lubrication. I want to at least get the hands moving, by way of the adjustment knob, before I put some power to it. We'll see how it goes.
Matt
keith460 10-10-2017 08:39 AM
It will take a bit of patience to even pry the bezel apart to remove the clear cover. Took me awhile to get it off and don't want to ever do that again.
I may have an extra polycarbonate cover that I made that you can have if you need it. I just have to make sure i have an extra laying around in my parts bin. It does not have the stepped edge of the OEM clock cover and is a 1/4" thick but works. Hard part is locating and drilling the hole for the adjustment knob and adding two small pins so it sits in the correct location of the housing. You'll see how it was made once you get it apart.
http://i123.photobucket.com/albums/o...ockrepair2.jpg
Matt1981CJ7 10-10-2017 08:39 AM
Thanks John,
Yes, I'm gong to take it apart, but other than removing the housing to get to the guts (as in your pic), I'm not sure what I can do from there.
If I can get it working, I think the light will be easy enough to address.
Matt
Matt1981CJ7 10-10-2017 08:47 AM
Keith,
I have a sinking feeling someone has already torn into this thing, because the crimp on the back of the bezel isn't smooth like I'd expect from a factory crimp. It's kinda wavy.
Oh well, live and learn.
Matt
The time now is 07:01 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
