No start after wiring new fuel gauge - JeepForum.com
post #1 of 3 Old 09-20-2019, 05:00 PM Thread Starter
johnnypac
johnnypac's Avatar
1980 CJ7
1980 Jeep cj7
5.3l vortec
Jeep was running perfectly.
The fuel gauge was not working so I replaced it. I bench tested the gauge with the dash apart and everything was working fine. I installed the gauge and everything was working fine. I came back later that evening and no start, no dash lights. The headlights and brake lights work just fine.
I have checked all of the fuses three times... I've checked ALL the grounds...
It's an LS swap so there is no ignition relay .
Any ideas?
johnnypac is offline
post #2 of 3 Old 09-21-2019, 07:01 AM Thread Starter
johnnypac
johnnypac's Avatar
1980 CJ7
Could I have fried the ign switch? Would that be possible? (I didn't remove batt neg)
post #3 of 3 Old 09-22-2019, 01:43 PM
Spieg8
1984 CJ8
Most likely you knocked some wires loose while messing around behind the dash. Are you getting power at the ignition switch? If not, you need to start tracing wires back from there.
When I was younger, I thought I was Don Quixote... turns out I'm just another donkey-hootie.
Spieg8 is offline
