Newbie here. Transfer case or..? - JeepForum.com
post #1 of 16 Old 09-09-2019, 07:25 PM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
This is the first I’ve ever owned. And I’m learning a lot already. Two weeks ago I bought a 1979 automatic CJ7 8 cylinder. It has front locking hubs that I think someone added? If I unlock the hubs the jeep won’t move. The front driveshaft continues to spin as it should, but the rear driveshaft will not spin. If I lift the Jeep off the ground both driveshafts spin as they should even under a load by pressing on the break. Ofcourse, unless I press hard enough to stop them. So, I can only drive it with the front hubs locked. I’m just confused, because it seems to work fine lifted off the ground. Any help would be great. Do I have a bad transfer case? Also, the 4 Wheel Dr. switch inside the glove box just seems to spin around and not do anything.
jpn2dfire is offline
post #2 of 16 Old 09-09-2019, 09:21 PM
RiverandSand
1980 CJ5
By the sounds of it you have a Quadra-Trac all wheel drive jeep. Unlocking the front hubs will cause the situation you describe by allowing the unit to think it's slipping there by putting all of the traction power to the front wheels. The knob in the glove box is for emergency traction lockup, it should be vacuum operated.
Look up jeeptech for more info on your setup.
Oh and welcome!
RiverandSand is offline
post #3 of 16 Old 09-10-2019, 07:41 AM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
Thanks for your help. I did some more reading on this. I still don’t understand. Why are the lock hubs there if the Jeep puts all the power to the front thinking it’s slipping? Also, when it’s in park or any gear, if the front hubs are not locked then the Jeep will roll like it’s in neutral.
post #4 of 16 Old 09-10-2019, 10:20 AM
RiverandSand
1980 CJ5
You will find owning a cj these things were subjected to all kinds of mods by POs, some good some not so good. A PO may have swapped in a non QT front axle or added the locking hubs for some reason.
post #5 of 16 Old 09-10-2019, 11:16 AM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
From what I’ve described, does it sound like its functioning properly? I’m just worried to drive it if not. And the whole thing about if the front hubs aren’t locked, the Jeep will roll like it’s in neutral no matter what gear it’s in.
post #6 of 16 Old 09-10-2019, 11:48 AM
Fourtrail
1974 CJ6
Yes the tcase is functioning correctly. It sounds like the e-drive switch is not. If you are worried about someone unlocking the hubs and your Jeep rolling away, then order a couple of these and swap out the hubs.
https://www.morris4x4center.com/driv...ge-999396.html
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #7 of 16 Old 09-10-2019, 12:32 PM
Spieg8
1984 CJ8
Make sure you have 6-bolt lockouts before you order the drive flanges linked above. If the PO made some swaps, you could have 5-bolt.
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #8 of 16 Old 09-10-2019, 12:44 PM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
Great. Thank you. Why would it roll when in park or any other gear when the front hubs aren’t locked?
post #9 of 16 Old 09-10-2019, 12:47 PM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
While we are talking about the transfer case... when accelerating from stop, if I don’t start very slowly there is a loud knocking noise under my feet.once I’m moving it stops. Only happens when accelerating from a stop. Would that be the chain loose? I’ve read those can go bad.
post #10 of 16 Old 09-10-2019, 02:20 PM
Fourtrail
1974 CJ6
Originally Posted by jpn2dfire View Post
Great. Thank you. Why would it roll when in park or any other gear when the front hubs arenít locked?
hard to explain and I haven't found a good visual that shows it well. your transfercase has an open differential in it that allows you to go around corners just like the differential in the axles. so just like the axles, if one tire is in the air (front hubs unlocked) then the jeep can roll.
While we are talking about the transfer case... when accelerating from stop, if I donít start very slowly there is a loud knocking noise under my feet.once Iím moving it stops. Only happens when accelerating from a stop. Would that be the chain loose? Iíve read those can go bad.
yes, you could have a loose chain, but you could also have a bad ujoint. need to climb underneath and check everything for looseness.
post #11 of 16 Old 09-10-2019, 03:23 PM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
Sounds great. Thanks again! I’ll be doing some more digging into it when I get off work in the morning.
post #12 of 16 Old 09-11-2019, 01:24 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Check all U joints, POs seem not to have grease guns and the poor things are often dry and full of metal dust. I found one once which had transformed the round shaft into square, surrounded by finely ground metal and rusty pins. The vibrations gave it away.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #13 of 16 Old 09-11-2019, 06:53 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
A couple of quick notes on the Q trac.
Stock units have a limited slip diff. Do not allow the front driveline to spin with a hub disengaged as it will wear out the unit. This is why everything spins with no load.
They came with drive flanges bolted to the front axles. The only reason to convert to hubs is to install a Mile Marker part time kit. If your rig doesn't have the MM kit, I would recommend a conversion back the the flanges.
The clunking noise under acceleration (heavy ratcheting sound) is usually caused by a stretched chain banging over one of the sprockets in the t case. This is the one big downfall of the system, as the chain drives both the front and rear drivelines, causing a more rapid degradation of the chain. The chain stretch can be checked through the drain hole at the bottom.
They run a special fluid so if you drain it be sure to get some. We used to use a non detergent 30wt and LS additive as an alternative. Worked fine and a lot cheaper.
Insure your emergency drive is working. Engage it and unlock the hubs. The Jeep should move normally. If it doesn't, then you need to check the vacuum hoses and the vacuum motor on the rear of the unit.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #14 of 16 Old 09-12-2019, 06:32 AM Thread Starter
jpn2dfire
jpn2dfire's Avatar
1979 CJ7
They have 5 bolt lockout hubs.
All the u-joints look good.
The e-4 four wheel drive is not working. So I’m going to have to check the vacuum and pump.
I think it’s the chain on that t-case. I’m going to start with changing the fluid and see what I can figure out.
Thanks guys!
post #15 of 16 Old 09-12-2019, 12:33 PM
Spieg8
1984 CJ8
They do make 5-bolt flanges similar to the 6-bolt. I'd recommend you get a pair.
Spieg8 is offline
