New Fuel Tank For CJ7? - JeepForum.com
 2Likes
post #1 of 31 Old 06-26-2020, 06:38 AM Thread Starter
thundercles
thundercles's Avatar
1979 CJ7
Well I got home from work yesterday and there was a puddle of gas under the CJ and a steady drip coming from the fuel tank. Got the tank dropped and emptied and there is a hole that developed in the center of the bottom of the tank. FWIY, the tank is a 15 gal Spectra Premium JP-1C which some PO put in.
Anyway, now I need to decide on a new fuel tank. I don't want to go back with this brand for obvious reasons. I would like to go with a poly tank but I am concerned about the hot exhaust pipe. This CJ has dual exhaust which run between the rear shackles and the tank on each side. The exhaust pipe is very close (may actually be touching) the current fuel tank. So do any of you have experience with a poly tank in close contact with exhaust pipe? Or can anyone recommend a better steel tank option? Thanks!
thundercles is offline
post #2 of 31 Old 06-26-2020, 06:55 AM
Fourtrail
1974 CJ6
MTS is normally the go to around here and most have had good luck with their tanks.
http://www.mtscompany.com/jeep.htm
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 31 Old 06-26-2020, 12:15 PM
StoneTower
I would try and find a OEM original 20 gallon poly tank. They are very well made and you have some extra fuel. The skid plates are the hardest part to find in rust states but several people on this forum have made their own skid plates for OEM 20 gallon tanks. The poly tanks never rust out.
Good luck.
StoneTower is offline
post #4 of 31 Old 06-26-2020, 01:05 PM
258
258's Avatar
^^^ - Go with the 20 gallon poly. I've had zero issues with exhaust pipes but I did mount my muffler at an angle to keep it away from the tank a bit. Plenty of clearance like that!
258 is offline
post #5 of 31 Old 06-26-2020, 06:49 PM
DV915
DV915's Avatar
1976 CJ7
I had a poly tank and dual exhaust.
The right side tail pipe was close to the tank so I placed a strip of adhesive backed heat shield on the tank, seemed to work ok.
Summit has quite an assortment of the stuff.
DV915 is offline
post #6 of 31 Old 06-26-2020, 09:03 PM
StoneTower
MTS also has a poly 15 gallon fuel tank that will bolt in.
0051
https://www.morris4x4center.com/gas-...oaAikkEALw_wcB
As far as I am concerned, it is too much money to spend on a 15 gallon tank.
You could run a 20 OEM tank and use a mandrel bent 90 to bring you passenger's side exhaust over to the driver's side and then Y it into a larger sided tailpipe. You will never know the difference in performance. You will probably appreciate the extra 5 gallons.
post #7 of 31 Old 06-27-2020, 04:03 AM
ddawg16
ddawg16's Avatar
If you plan to keep the jeep for a long time....go 20 gal....1/4 less stops for gas. 1/4 Increase in mileage.
Do a search.....lots of options. Of course, if money is an issue.....
ddawg16 is offline
post #8 of 31 Old 06-27-2020, 05:50 AM
StoneTower
There are lots of options for tanks, but if you want 20 gallons, the best available option for most is a OEM tank that is in good shape. The MTS tank hangs down too far. I talked to MTS several months ago about a unrelated issue and told them how poorly designed their 21 gallon tank was. The guy agreed and told me that they made the mold for that tank for a customer and produced a number of tanks. When the contract ran out, they continued to use the mold to make tanks and have sold many to many happy customers. He said the molds are EXTREMELY expensive to make. He also said they are working on a exact OEM replacement tank that will be released in the future. We will see if that ever happens.
There is also an aluminum tank option which costs around $1300.00. Unless you have a need to stretch the wheelbase (this tank allows this) or have lots of cash to burn, this is probably not the best option for most. Most of us have between $6k and $10k invested in our original purchase (nice Jeep...not a POS) and $1300.00 is a huge investment for a tank in a $6K-$10K toy.
In California, where we generally do not have too many rust problems, I see the OEM 20 gallon tanks with the skid plates from time to time for a reasonable amount of money. In the rust belt, where CJs disintegrate, I would think the poly tanks would be one of the few usable parts after everything else rusts away. If they do not get crushed, the poly tanks should be more plentiful there because there are less Jeeps to go with them. The skid plate would probably be the hard part to find in the rust belt.
post #9 of 31 Old 06-27-2020, 06:37 AM
Axhammer
Axhammer's Avatar
Holley makes an affordable 15 gallon steel replacement tank.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #10 of 31 Old 06-27-2020, 07:47 AM
StoneTower
I did not know about the Holley Sniper tank. The Sniper TBI units are really nice. My son's 1966 Mustang is going to get one.
You could also go with some of the cheaper 15 gallon replacements (maybe like what he had before) and use a gas tank sealer on the new tank to coat the new tank.
You could use
POR15 Fuel Tank Sealer 8 oz.
or
Eastwood's gas tank sealer
With a new tank, acetone and then the sealer should be all that is required.
post #11 of 31 Old 06-27-2020, 05:22 PM
gosupes
The OEM 20 gal poly tank hangs quite a bit lower than the OEM style 15 gal tanks. I went the other way, I pulled the 20 gallon and went with the 15. I don't need the extra capacity and was glad to get some added ground clearance.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #12 of 31 Old 06-27-2020, 07:17 PM
StoneTower
Please define quite a bit. The MTS 21 gallon tank uses the stock 15 gallon skid plate and has a 4 inch spacer that must be installed for it to work. I would think at most you gained an inch or two if you went from an OEM 20 to a 15 which use different skid plates. I have never drug my 20 with 33 inch tires and BDS 4" lift springs.
258 likes this.
post #13 of 31 Old 06-27-2020, 08:47 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
An unusual location for a hole, a steel tank will usually hole on the top or the side seams. the bottom is covered in fuel and can only rust on the outside.
I welded up Bagusjeep's tank 10 years ago and she has been fine ever since. It had rust holes on the top. You hav eto be careful that all fuel vapours are gone before welding but apart from that it is a simple job.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #14 of 31 Old 06-29-2020, 03:36 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I love my 21 gallon poly! Had him since 1996!
No more exterior rusting/ no more internal ethanol caused rusting!
Since I'm "over" my Jeep thrashing days, It gets me around a lot further.
If I were still doing the thrashing of yesteryear, I'd probably have torn it off!
Here's a pic from the rear of the "dangle-age" I have now. Notice an included "extension" is used on the original skid plate to allow for the extra tank capacity.
----JEEPFELLER
JEEPFELLER is offline
post #15 of 31 Old 06-29-2020, 06:28 PM
StoneTower
If the 21 gallon works for you that is great. If you had purchased and installed an original 20 gallon tank, you would have a couple of more inches clearance, an angled back on the skid plate for better departure angle and they can be had for as little as $50.00 I have seen several for sale at that price.
----JEEPFELLER
